I can’t add that mute timing to the “Default policy” under “Notification policies”: it’s not available when I edit that policy (no dropdown for timings).
I can click “New nested policy” and add a nested policy without a matcher. This should/might match ALL instances, right?
Is that the correct way to do that? For me it seems not to work, last night there still were alerts sent.
goal: per default alerts should be muted during a defined time window (backups).
used release: grafana-oss-10.1.4 in a docker-compose-stack
I have a Severity label as well to define different mute timings. Warnings get muted during business hours and critical is 24/7. The severity level is calculated dynamically
Thanks for that. It seems I don’t have that yet. Browsing for these “Custom Labels” now, pls specify where I find them, I can’t find it so far. Is it under “Contact points - Notification templates” ?
