Go to PM UI and on container page.
Select the namespace of your setup.
Click on pod, you will see 1 pod each say (FE master pod, P1 ,collector, distributor and so on).
Now you delete 1 pod . once the pod come up with different name.
Now you see 2 pod (1 is new and another is old one).
if we repeat the step 4 and 5 immediately the you will see 3 entries of pod.
old pods which doesn’t exist also shows in grafana UI and is not removed.
After sometime say 10-15 min if we refresh then the old pod goes from grafanaUI.
ACTUAL OUTPUT:
Once the pod is deleted from the backend , grafana UI should only show the latest one immediately.
