Thanks for your reply! I attach a redacted sample config.river file that we currently use for the agent (note I commented out the 2 multiline parsing stages).
I also attach an example from our db logs - note as I said, I couldn’t see any pattern. It’s both application and db logs, sometimes it’s duplicate lines, sometimes it’s 3x/4x etc., sometimes it is the first line, sometimes not. Also out of order and then appearing in multiple log chunks. The max_lines config seems to work. Changing it (to 64) does not help.
I also attach our Dockerfile, docker-compose file (for Docker swarm), loki config, even if I don’t think it matters much for this topic.
Thanks in advance & let me know if you need further info.
example log:
2024-07-11 08:02:50.824 UTC [55186] LOG: execute <unnamed>: /* delete from Object object
where object.createDate < ?1 and not exists (select 1
from Object object
where object.id = otherObject.id) */ delete from table1 bte1_0 where bte1_0.create_date<$1 and not exists(select 1 from table2 bpe1_0 where bte1_0.id=bpe1_0.trip_id)
from Object object
Dockerfile for custom agent image:
FROM grafana/agent:v0.39.2
COPY config.river /etc/agent/config.river
ENV AGENT_MODE=flow
CMD ["run", "--server.http.listen-addr=0.0.0.0:12345", "/etc/agent/config.river"]
docker-compose.yaml-excerpt:
agent:
image: internal-registry/grafana-agent:latest
volumes:
- /var/lib/docker/containers:/var/lib/docker/containers:ro
- /var/run/docker.sock:/var/run/docker.sock
environment:
- HOSTNAME=redacted
- LOKI_URL=http://loki:3100/loki/api/v1/push
- TENANT_ID=redacted
ports:
- "12345:12345"
depends_on:
- loki
networks:
- internal
- prometheus
labels:
logging: "grafana-agent"
prometheus.scrape: "true"
prometheus.port: "12345"
deploy:
labels: (redacted)
config.river:
discovery.docker "docker_scrape" {
host = "unix:///var/run/docker.sock"
refresh_interval = "5s"
filter {
name = "label"
values = ["logging=grafana-agent"]
discovery.relabel "docker_scrape" {
targets = []
rule {
source_labels = ["__meta_docker_container_id"]
target_label = "docker_container_id"
rule {
source_labels = ["__meta_docker_container_name"]
regex = "/(.*)"
target_label = "container_name"
rule {
source_labels = ["__meta_docker_container_log_stream"]
target_label = "logstream" // i.e. stdout/stderrr.
// Containers will typically log to either one.
// (This rule does not appear in the Grafana Agent documentation, but works as a Promtail configuration.)
rule {
source_labels = ["__meta_docker_container_label_com_docker_swarm_service_name"]
target_label = "docker_service_name"
rule {
source_labels = ["__meta_docker_container_label_com_docker_stack_namespace"]
target_label = "docker_stack_namespace"
loki.source.docker "docker_scrape" {
targets = discovery.docker.docker_scrape.targets
forward_to = [loki.process.docker_scrape.receiver]
relabel_rules = discovery.relabel.docker_scrape.rules
loki.write "default" {
endpoint {
url = env("LOKI_URL")
tenant_id = env("TENANT_ID")
external_labels = {}
loki.process "docker_scrape" {
forward_to = [loki.write.default.receiver]
stage.static_labels {
values = {
host_name = env("HOSTNAME"),
// ############################### APPLICATION ###############################
stage.match {
// This stage will parse non-JSON logs.
selector = "{docker_service_name=~\".*application_name.*\", log_status!=\"processed\"} !~ \"^{.*.application.:.application_name.}$\""
// The wildcards are '"',but single quotes are not allowed.
// We use 'processed' as a custom label to only process logs in following stages not yet processed.
// Multiline currently disabled, as leading to duplicate and out-of-order logs.
// stage.multiline {
// firstline = "^(x|y|z|v|other).*?$"
// max_wait_time = "3s" // Defaults to 3s
// max_lines = 128 // Defaults to 128
stage.template {
source = "docker_stack_namespace"
template = "{{if .Value }} {{- .Value -}} {{else}} {{- \"(Not running on Docker Swarm)\" -}} {{end}}"
stage.regex {
expression = "^.*?(?P<level>DEBUG|INFO|WARN|ERROR|FATAL).*?$"
stage.labels {
values = {
level = null,
values = {
pipeline = "application_name_plain",
processing_status = "processed",
// ###################### APPLICATION JSON ######################
stage.match {
// This stage will parse application JSON logs.
selector = "{docker_service_name=~\".*application_name.*\", processing_status!=\"processed\"} |~ \"^{.*.application.:.application_name.}$\""
// The end is a custom JSON attribute added to the end of all application_name log4j logs via the JSON appender.
stage.json {
// For examples of raw JSONs produced by application_name, see: REDACTED
expressions = {
time = "timeMillis",
class_name = "loggerName",
level = "level",
message = "message",
thread = "thread",
thrown = "thrown",
marker = "marker",
stage.json {
source = "marker"
expressions = {
marker_name = "name",
stage.timestamp {
source = "time"
format = "UnixMS"
action_on_failure = "skip"
stage.labels {
values = {
level = null,
thread = null,
marker_name = null,
stage.template {
stage.template {
// The thrown JSON is currently just passed without processing for potential subsequent evaluation.
source = "thrown"
template = "{{if .Value }} {{- \"\\n\\nThrown:\\n\" -}}{{- .Value -}} {{else}} {{- \"\u200B\" -}} {{end}}" // \u200B = zero width space
stage.template {
source = "marker_name"
template = "{{if .Value }} {{- .Value -}} {{else}} {{- \"\u200B\" -}} {{end}}" // \u200B = zero width space
stage.template {
source = "class_name"
template = "{{if .Value }} {{- .Value -}} {{else}} {{- \"-\" -}} {{end}}"
stage.template {
source = "output"
template = "{{ .docker_stack_namespace }}: {{ ToUpper .level }} [{{ .thread }}] {{ .class_name }}[{{ .marker_name }}] - {{ .message}}{{- .thrown -}}"
stage.output {
source = "output"
values = {
pipeline = "log_application_name_json",
// ############################### DB ###############################
stage.match {
selector = "{docker_service_name=~\".*db.*\", processing_status!=\"processed\"} !~ \"^{.*}$\"" // Assuming we do not have any other services to log with 'db' in the name.
// firstline = "^\\d{4}-\\d{2}-\\d{2}\\s\\d{2}:\\d{2}:\\d{2}.\\d{3}\\sUTC.*?$"
stage.regex {
expression = "^.*?(?P<level>DEBUG|DETAIL|LOG|INFO|WARNING|ERROR|FATAL|PANIC)(.|\\n)*?$"
stage.regex {
expression = "^(?P<time>\\d{4}-\\d{2}-\\d{2}\\s\\d{2}:\\d{2}:\\d{2}.\\d{3}\\sUTC)(.|\\n)*?$"
stage.timestamp {
source = "time"
format = "2006-01-02 15:04:05.999 MST" // See: https://grafana.com/docs/loki/latest/send-data/promtail/stages/timestamp/
stage.labels {
values = {
level = null,
values = {
pipeline = "log_db_plain",
// ############################### AGENT ###############################
stage.match {
selector = "{docker_service_name=~\".*agent.*\", processing_status!=\"processed\"}"
values = {
pipeline = "log_agent",
stage.regex {
expression = "^ts=(?P<time>[T\\d-:.Z]*) level=(?P<level>[a-zA-Z]+).*?"
stage.template {
source = "level"
template = "{{ ToUpper .level }}"
stage.labels {
values = {
level = null,
stage.timestamp {
source = "time"
format = "2006-01-02T15:04:05.999999999Z"
// ############################### LOKI ###############################
stage.match {
selector = "{docker_service_name=~\".*loki.*\", processing_status!=\"processed\"}"
values = {
pipeline = "log_loki",
stage.regex {
expression = "^level=(?P<level>[a-zA-Z]+) ts=(?P<time>[T\\d-:.Z]*).*?"
stage.template {
source = "level"
stage.labels {
values = {
level = null,
stage.timestamp {
source = "time"
// ############################### GRAFANA ###############################
stage.match {
selector = "{docker_service_name=~\".*grafana.*\", processing_status!=\"processed\"}"
values = {
pipeline = "log_grafana",
stage.regex {
expression = ".*?(logger=(?P<logger>[a-zA-Z\\.]+))?.*?t=(?P<time>[T\\d-:.Z]*) level=(?P<level>[a-zA-Z]+)?.*?"
stage.template {
source = "level"
stage.labels {
values = {
level = null,
logger = null,
stage.timestamp {
source = "time"
// ############################### UNPROCESSED ###############################
stage.match {
selector = "{processing_status!=\"processed\"}"
stage.regex {
expression = "^.*?(?P<level>DEBUG|INFO|WARN|WARNING|ERROR|FATAL|debug|info|warn|warning|error|fatal).*?$"
stage.labels {
values = {
level = null,
values = {
processing_status = "unprocessed",
loki.yaml:
# Adapted from: https://github.com/grafana/loki/blob/main/cmd/loki/loki-local-config.yaml and https://github.com/grafana/loki/issues/4613#issuecomment-1018367471
# The module to run Loki with. Supported values
# all, distributor, ingester, querier, query-frontend, table-manager.
# [target: <string> | default = "all"]
target: all
auth_enabled: true # Header X-Scope-OrgID must be present if true (multi-tenant mode). This is not about an actual auth layer: https://github.com/grafana/loki/blob/main/docs/sources/operations/authentication.md
server:
http_listen_port: ${HTTP_LISTEN_PORT:-3100}
http_server_read_timeout: 300s
http_server_write_timeout: 300s
log_level: ${LOG_LEVEL:-info} #Supported values [debug, info, warn, error]
# Again, this is adapted from the link above, and partly differing from config found in the docs using 'storage_config'
common:
instance_addr: ${INSTANCE_ADDR:-127.0.0.1}
path_prefix: /loki
storage:
filesystem:
chunks_directory: /loki/chunks # When run in single tenant mode, all chunks are put in a folder named 'fake' (auth_enabled: false)
rules_directory: /loki/rules
ring:
kvstore:
store: inmemory
heartbeat_timeout: 10m # https://grafana.com/blog/2021/02/16/the-essential-config-settings-you-should-use-so-you-wont-drop-logs-in-loki/
replication_factor: 1 # 3 would be recommended for availability. However you need to have rings (distributed hashtables)
# set up explicitly and have additional ingester members join them.
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v12# Adapted from: https://github.com/grafana/loki/blob/main/cmd/loki/loki-local-config.yaml and https://github.com/grafana/loki/issues/4613#issuecomment-1018367471
target: all
server:
common:
path_prefix: /loki
storage:
filesystem:
ring:
kvstore:
store: inmemory
schema_config:
configs:
store: tsdb
schema: v12
index:
prefix: index_
period: 24h # The index period must be 24h for the compactor.
ingester:
chunk_encoding: snappy # https://grafana.com/blog/2021/02/16/the-essential-config-settings-you-should-use-so-you-wont-drop-logs-in-loki/
# Less compressibility but faster performance than gzip (default encoding).
chunk_target_size: 1572864 # https://grafana.com/docs/loki/latest/configure/bp-configure/#use-chunk_target_size
# We could additionally consider WAL enabling to prevent log loss in event of a crash. https://grafana.com/docs/loki/latest/operations/storage/wal/#write-ahead-log
chunk_idle_period: 2h # To match 2h default of ingester.max_chunk_age (https://grafana.com/docs/loki/latest/operations/storage/filesystem/)
query_range:
max_retries: 5 # | default = 5]
cache_results: true # | default = false]
results_cache:
cache:
embedded_cache:
enabled: true # | default = false]
max_size_mb: 100 # | default = 100]
chunk_store_config:
chunk_cache_config:
embedded_cache:
compactor:
shared_store: filesystem
delete_request_store: filesystem # See https://grafana.com/docs/loki/latest/operations/storage/logs-deletion/#configuration
working_directory: /loki/tsdb-shipper-compactor
compaction_interval: 10m # dictates how often compaction and/or retention is applied. If the Compactor falls behind, compaction and/or retention occur as soon as possible.
retention_enabled: true # Without this, the Compactor will only compact tables.
retention_delete_delay: 2h # is the delay after which the Compactor will delete marked chunks.
retention_delete_worker_count: 150 # specifies the maximum quantity of goroutine workers instantiated to delete chunks.
limits_config:
# For more granular retention, see https://grafana.com/docs/loki/latest/operations/storage/retention/#configuring-the-retention-period (e.g. log retention per service)
retention_period: ${RETENTION_PERIOD:-30d}
# Limit how far back in time series data and metadata can be queried,
# up until lookback duration ago.
# This limit is enforced in the query frontend, the querier and the ruler.
# If the requested time range is outside the allowed range, the request will not fail,
# but will be modified to only query data within the allowed time range.
# The default value of 0 does not set a limit.
# CLI flag: -querier.max-query-lookback
max_query_lookback: 90d
# Examples for more advanced config such as query parallelization, see e.g. https://github.com/grafana/loki/issues/10257
frontend:
# Maximum number of outstanding requests per tenant per frontend; requests
# beyond this error with HTTP 429.
# CLI flag: -querier.max-outstanding-requests-per-tenant
max_outstanding_per_tenant: 2048 # default = 2048]
# Compress HTTP responses.
# CLI flag: -querier.compress-http-responses
compress_responses: true # default = true]
# Log queries that are slower than the specified duration. Set to 0 to disable.
# Set to < 0 to enable on all queries.
# CLI flag: -frontend.log-queries-longer-than
log_queries_longer_than: 20s # | default = 0s ]
query_scheduler:
# Maximum number of outstanding requests per tenant per query-scheduler.
# In-flight requests above this limit will fail with HTTP response status code
# 429.
# CLI flag: -query-scheduler.max-outstanding-requests-per-tenant
max_outstanding_requests_per_tenant: 32000 # default = 32000
#ruler:
# storage:
# type: local
# local:
# directory: /data/loki/rules # volume, directory to scan for rules
# rule_path: /data/loki/rules-temp # volume, store temporary rule files
# alertmanager_url: "https://alertmanager.example.com"
# enable_alertmanager_v2: true
# alertmanager_client:
# basic_auth_username: "{{ loki_alertmanager_username }}"
# basic_auth_password: "{{ loki_alertmanager_password }}"
# By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
# analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
# Statistics help us better understand how Loki is used, and they show us performance
# levels for most users. This helps us prioritize features and documentation.
# For more information on what's sent, look at
# https://github.com/grafana/loki/blob/main/pkg/analytics/stats.go
# Refer to the buildReport method to see what goes into a report.
# If you would like to disable reporting, uncomment the following lines:
#analytics:
# reporting_enabled: false
index:
prefix: index_
ingester:
query_range:
results_cache:
cache:
embedded_cache:
chunk_store_config:
chunk_cache_config:
embedded_cache:
compactor:
limits_config:
frontend:
query_scheduler:
# 429.
#ruler:
# storage:
# type: local
# local:
#analytics:
