Multi-step forms
Hey!
What’s the recommended approach for multi step forms?
I want to stress test a checkout flow, which consists of loading the product page, adding to cart, loading the checkout, filling out another form and submitting it.
Much appreciated!
Hi @till
Welcome to the forum.
We don’t have a “recommended approach” per se but there are multiple examples in k6 documentation at k6 Documentation that can be used as a basis and then expanded upon. For instance, if you need to submit a form specifically, you can use this snippet:
Response.submitForm( [params] )
Since you mentioned writing a flow for user’s journey on a website, you might find this repo useful:
It’s written for test e-shop hosted by k6 team but this code can be relatively quickly adapted for any other e-shop.
Hope that helps :slightly_smiling_face:
