Grafana v11.3.1 -
Setup multi cluster and region grafana stack deployment for centralized logs and metrics
Using the kubernetes helm charts -
What happened?
Technical challenges in terms of authentication and loki/mimir configuration
Able to see logs and metrics in one place handling multi clusters located in multiple regions.
Using AWS as the cloud provider and loki-distributed and mimir-distributed helm charts for the deployment.
loki version - loki-distributed-0.79.3 app version: 2.9.8
mimir version - mimir-distributed-5.5.0 app version: 2.14.0
In terms of architectural point of view., we want to achieve central observability for the kubernetes logs and metrics.
- we will have one central loki instance running in AWS with S3 as as tsdb storage
- All the kubernetes clusters will forward the pod logs to the central loki instance via grafana agent deployed in the clusters.
- we will have a central grafana UI that connect to loki datasource and logs can be viewed.
- Same steps (1-3) for mimir as well
I have few questions around it…
- Is this the right approach for the multi region / cluster architecture ?
- How does each cluster gets authenticated to the central loki … ? they all share same user/pass ?
- Need some inputs on setting the tenant value via (X-Scope-OrgID) … can we set that to the k8s cluster name ? … I need to know how it will be used for ?
- Do i need separate loki datasource configured for each of the X-scope-OrgID ?
Please shed some lights on it…thanks
