Hi there, is there any example using MSAL library or other kind of implementation using Azure AD - OAuth2 Authentication with Auth code grant - Microsoft identity platform and OAuth 2.0 authorization code flow - Microsoft Entra | Microsoft Learn. I am stuck for a bit longer because I am unable to authenticate to the API using this flow and there is no such examples.
Hi @stanislav3885,
is it the same issue you posted in the previous topic OAuth2 Authentication? If yes, can you continue there, please?
Did you try the suggestion provided there? If you are going to post there with your attempts, you should consider posting an anonmized version of your script so we can evaluate which part is failing for you.
