Hi
Do we have option to monitor Loki similar to what we use for grafana agent ( ```
max_over_time(up{job=“integrations/agent”}[1h])
Any suggestions would be very helpfull.
We are using grafana agent to pull the logs from servers .
Thanks
K Suresh
Hi @suresh300567
What exactly do you want to monitor? That Loki is up and running correctly?
Hi @anon74857911
Yes , we want to know if loki is up and running fine
Are you scraping Loki’s metrics with the agent or Prometheus, for example?
system
Closed
5
