Hi, I want to export metrics from a MongoDB replica set running in Kubernetes, and I want to see the metrics in Grafana Cloud.
I have the Kubernetes Grafana Agent running using the Kubernetes operator. I can see Kubelet metrics, pod metrics, etc.
I went ahead and set up an Integration CRD for mongodb. This is what the CRD looks like:
apiVersion: monitoring.grafana.com/v1alpha1
kind: Integration
metadata:
creationTimestamp: "2023-05-11T00:01:26Z"
labels:
agent: grafana-agent
namespace: metrics
resourceVersion: "2645330"
uid: 0f022cf6-1d64-4a46-ac84-7b641dcc7dd1
spec:
config:
mongodb_uri: <VALID_MONGODB_URI>
type:
allNodes: true
unique: true
The grafana-agent-0 and grafana-agent-integration* pods run properly, even after I restart these pods. Their logs show no errors.
But I cannot see any data in the MongoDB monitoring dashboards. Help please?
Other notes:
- I know the MongoDB URI is valid because I tested using that URI from another pod.
- As you can see in the CRD, I omitted
relabel_configs, which the docs mark as necessary. Seems like the latest version of the agent does no longer accepts that config (including the value makes thegrafana-agentpod error out).
