Hi!
Is there a way to prevent from editor user to delete dashboard?
Thanks.
Hi!
Thanks.
Hi, @hagai!
By default, there’s no option to do that. It would require you to prepare custom ACLs. Maybe a read-only editor aka editing viewer role would be a great fit there?
Best regards,
Lukas
Hi Lukas,
How can I change to editing viewer and what is the difference between viewer and editing viewer.
Is there an option for roles per report?
Thanks,
Hagai.
