I’m testing a grafana tempo chart (v2.4.2) on my k8s cluster, everything works pretty well except the MetricsGenerator component.
No traces_spanmetrics_* metrics are generated.
tempo-config.yaml
multitenancy_enabled: false
cache:
caches:
- memcached:
host: observability-rci-memcached
service: memcache
timeout: 500ms
consistent_hash: true
roles:
- bloom
- trace-id-index
compactor:
compaction:
block_retention: 48h
ring:
kvstore:
store: memberlist
distributor:
ring:
kvstore:
store: memberlist
metric_received_spans:
enabled: true
receivers:
jaeger:
protocols:
thrift_http:
endpoint: 0.0.0.0:14268
grpc:
endpoint: 0.0.0.0:14250
otlp:
protocols:
http:
endpoint: 0.0.0.0:55681
grpc:
endpoint: 0.0.0.0:4317
querier:
frontend_worker:
frontend_address: observability-rci-grafana-tempo-query-frontend-headless:9095
ingester:
lifecycler:
ring:
replication_factor: 1
kvstore:
store: memberlist
tokens_file_path: /bitnami/grafana-tempo/data/tokens.json
metrics_generator:
ring:
kvstore:
store: memberlist
processor:
service_graphs:
# Wait is the value to wait for an edge to be completed.
wait: 10s
span_metrics:
histogram_buckets: [0.002, 0.004, 0.008, 0.016, 0.032, 0.064, 0.128, 0.256, 0.512, 1.02, 2.05, 4.10]
enable_target_info: true
local_blocks:
filter_server_spans: false
registry:
collection_interval: 15s
external_labels:
source: tempo
cluster: test
storage:
path: /bitnami/grafana-tempo/data/wal
remote_write:
- send_exemplars: true
url: http://rancher-monitoring-prometheus.cattle-monitoring-system.svc.cluster.local:9090/api/v1/write
memberlist:
abort_if_cluster_join_fails: false
join_members:
- observability-rci-grafana-tempo-gossip-ring
overrides:
per_tenant_override_config: /bitnami/grafana-tempo/conf/overrides.yaml
server:
http_listen_port: 3200
storage:
trace:
backend: s3
s3:
bucket: ${S3_BUCKET}
endpoint: ${S3_ENDPOINT}
access_key: ${S3_ACCESS_KEY}
secret_key: ${S3_SECRET_KEY}
blocklist_poll: 5m
local:
path: /bitnami/grafana-tempo/data/traces
wal:
overrides.yaml
overrides:
defaults:
metrics_generator:
processors: [service-graphs, span-metrics, local-blocks]
max_active_series: 1000
Checking distributor’s status page (http://distributor/metrics-generator/ring?tokens=true) show metrics-generator is active and have 100% ownership
Checking http://metrics-generator/status/overrides/defaults
Runtime overrides
Source of runtime overrides: defaults
metrics_generator:
processors:
- service-graphs
- span-metrics
- local-blocks
ingestion_time_range_slack: 0s
Prometheus has remote-write enabled and tested it from tempo’s namespace
Checking prometheus for metrics:
- tempo_distributor_ingester_clients has 1 active client
- tempo_distributor_metrics_generator_clients has 0 active clients
- traces_spanmetrics_* no metrics at all
I’m probably missing/messed up a configuration but I’m running out of clues…
Thanks
