Alguien sabría decirme esa métrica cual es, ya que no doy con ella.
Gracias!
Gracias!
Hey @sgomez2
"Metrics, to tell you how many users are connected to a computer.
I’m not sure if anyone can tell me what this metric is, because I can’t find it.
Thanks!"
First, you should translate your message in English, for universal understanding.
Secondly, we need more details about your configuration… What are your collectors? What’s the OS of the computer?
Regards
Hello, would it be a Windows 10 operating system, would the computers be desktop PCs or laptops, compilers, what exactly are you referring to?
Sorry for Spanish ![]()
Hey
Was your question related to “Which metric to fetch how many users are connected to a computer?”. If that’s so, we need to know on which OS you want to check how many users are connected: metrics between Windows, Mac or Linux are not the same… We also need to know how you collect the data about the machine… Prometheus, Telegraf, etc.?
Good afternoon, here we all use the Windows operating system, so it would be to check it with that operating system, Prometheus is the metrics we use to obtain the data
