Memory utilization of ec2 instances
hi ,
I’m kinda new to grafana , Just trying to figure to how to monitor memory utilization of ec2 instances ?
any Help is appreciated
Hello any workaround ?
you will have to configure cloudwatch and install your cloudwatch agent to send the data to that datasource
https://docs.aws.amazon.com/AmazonCloudWatch/latest/monitoring/metrics-collected-by-CloudWatch-agent.html
from there youi can add panels and dashboards to visualize your data
I’ve installed the agent. how to I create a query to get the metrics in grafana?
you add the datasource then create dashboards and panels that reads from the datas ource cloud watch
