Without the cluster label being a part of the metrics, the memcached integration dashboard version 0.0.5 doesn’t display data. When I copy the dashboard and remove the cluster variable and references, data appears in the graphs. This is similar to the way the Linux dashboards were.
Would it be possible to remove the requirement to have the cluster label from the dashboard?
