When I run a query on Grafana,the results cannot turn out,but show the alert:maximum of series (500) reached for a single query
Is there anywho can tell me how to fix it
@absoultdev, can you share more about the datasource you’re querying or include a screenshot of the query that shows the datasource and error? some of the errors you might see in a query are returned as the query response from the source and some might come from grafana.
Can you help ? same error
Just go to the loki-local-config.yaml, then find the limits_config configuration.
Then modify this to the limits_config:
limits_config:
reject_old_samples: true
retention_period: 360h
max_query_series: 100000
max_query_parallelism: 2
default value of the max_query_series is 500, so make it bigger as you need.
max_query_parallelism is the max CPU that you can use for parallelism
Regards,
Fadjar Tandabawana
From loki --help:
-querier.max-query-parallelism int
Maximum number of queries will be scheduled in parallel by the frontend. (default 32)
I don’t think that is the number of CPUs, from what I can tell.
EDIT: deleted and posted as a reply to previous comment.
