Math based on another panel
Not sure this is possible but my situation is that I have 2 queries and 5 transformations just to get the result I need from InfluxDB using InfluxQL. This result is only half the equation. What I then need is another set of queries and transformations to get another number and perform some maths with using the first number I described.
I want to get a total of multiple columns, filtering out any repeating values. I’d then like a count of these values. With this I can do some simple maths.
At this point am I better to use flux and possibly create a query that can nail it in one go? There are other dashboards relying on InfluxQL. Will switching the data source settings to flux break them?
Please provide sample data as inline csv
for all data points
Col1,col2,date
Foo,33
then the final result wanted from all of these data points
Yes, but 1) Flux is not being actively developed by InfluxDB for about 2 years now (but is being actively supported and developed by Fluxpipe) and 2) Flux has a steeper learning curve than InfluxQL (at least for some people).
I am pretty sure you have to choose Flux, InfluxQL or SQL for each instance of InfluxDB that you set up in Grafana. So if you’d have to create two Influx databases (one for Flux and one for InfluxQL) and send the relevant data to each, etc. Not impossible, but might be more than you wished for.
Hopefully this works
Raw data something like - Note weight diff query included
Time weight.value { tagName: Net_Weight_Head_1 } weight.value { tagName: Net_Weight_Head_10 } weight.value { tagName: Net_Weight_Head_11 } weight.value { tagName: Net_Weight_Head_12 } weight.value { tagName: Net_Weight_Head_2 } weight.value { tagName: Net_Weight_Head_3 } weight.value { tagName: Net_Weight_Head_4 } weight.value { tagName: Net_Weight_Head_5 } weight.value { tagName: Net_Weight_Head_6 } weight.value { tagName: Net_Weight_Head_7 } weight.value { tagName: Net_Weight_Head_8 } weight.value { tagName: Net_Weight_Head_9 } weight.diff { tagName: Net_Weight_Head_1 } weight.diff { tagName: Net_Weight_Head_10 } weight.diff { tagName: Net_Weight_Head_11 } weight.diff { tagName: Net_Weight_Head_12 } weight.diff { tagName: Net_Weight_Head_2 } weight.diff { tagName: Net_Weight_Head_3 } weight.diff { tagName: Net_Weight_Head_4 } weight.diff { tagName: Net_Weight_Head_5 } weight.diff { tagName: Net_Weight_Head_6 } weight.diff { tagName: Net_Weight_Head_7 } weight.diff { tagName: Net_Weight_Head_8 } weight.diff { tagName: Net_Weight_Head_9 }
18/02/2025 6:48 901 897 900 906 904 903 899 902 899 926 900 900 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 898 -1.6
18/02/2025 6:48 920 -5.5
18/02/2025 6:48 902 2.6
18/02/2025 6:48 900 0.8
18/02/2025 6:48 900 2.9
18/02/2025 6:48 901 900 900 906 904 903 899 902 898 920 902 900 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 909 8.6
18/02/2025 6:48 909 2.7
18/02/2025 6:48 906 4.7
18/02/2025 6:48 896 -8.3
18/02/2025 6:48 909 5.4
18/02/2025 6:48 906 900 909 909 896 909 899 902 898 920 902 900 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 905 5.5
18/02/2025 6:48 902 0.2
18/02/2025 6:48 893 -5.1
18/02/2025 6:48 911 -9.6
18/02/2025 6:48 900 -2.3
18/02/2025 6:48 903 2.9
18/02/2025 6:48 906 900 909 909 896 909 905 902 893 911 900 903 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 900 -8.8
18/02/2025 6:48 911 2.3
18/02/2025 6:48 903 -2.6
18/02/2025 6:48 899 2.6
18/02/2025 6:48 903 900 900 911 899 909 905 902 893 911 900 903 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 904 -4.6
18/02/2025 6:48 909 4.4
18/02/2025 6:48 901 -1.3
18/02/2025 6:48 898 5.4
18/02/2025 6:48 913 2.6
18/02/2025 6:48 903 900 900 911 899 904 909 901 898 913 900 903 0 0 0 0 0 0 0 0 0 0 0 0
18/02/2025 6:48 905 5.3
18/02/2025 6:48 907 3.2
18/02/2025 6:48 900 -0.5
18/02/2025 6:48 903 2.7
18/02/2025 6:48 906 -5.1
18/02/2025 6:48 900 -3
After transformations something like
18/02/2025 6:48 901
18/02/2025 6:48 904
18/02/2025 6:48 903
18/02/2025 6:48 899
18/02/2025 6:48 902
18/02/2025 6:48 898
18/02/2025 6:48 920
18/02/2025 6:48 902
18/02/2025 6:48 900
18/02/2025 6:48 900
18/02/2025 6:48 909
18/02/2025 6:48 909
18/02/2025 6:48 906
18/02/2025 6:48 896
18/02/2025 6:48 909
18/02/2025 6:48 905
18/02/2025 6:48 902
18/02/2025 6:48 893
18/02/2025 6:48 911
18/02/2025 6:48 900
18/02/2025 6:48 903
18/02/2025 6:48 900
18/02/2025 6:48 900
18/02/2025 6:48 911
18/02/2025 6:48 903
18/02/2025 6:48 899
18/02/2025 6:48 904
18/02/2025 6:48 909
18/02/2025 6:48 901
18/02/2025 6:48 898
18/02/2025 6:48 913
18/02/2025 6:48 905
18/02/2025 6:48 907
18/02/2025 6:48 900
18/02/2025 6:48 903
18/02/2025 6:48 906
18/02/2025 6:48 900
After the transforms to get only the changing weight I’d like to
  • Add up all weights
  • Count the amount of weights
  • Multiply the number of weights by a set number to get a total
  • Calculate total difference
Thank you. It may be an idea to set another instance up to try out Flux
that does not look like the raw data from your database, it looks pivoted
please post like the following the data exactly as it is in your influxdb
foo,bar,date,value
jedi,luke,2025-02-18 13:33:33,34.1
Sorry. Direct from InfluxDB
_start _stop _time _value _field _measurement group line machine site tagName
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:09:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:10:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:11:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:12:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:13:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:14:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:15:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:16:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:17:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:18:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:19:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:20:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:21:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:22:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:23:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:24:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:25:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:26:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:27:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:28:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:29:00Z 1.6000000000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 1.5999999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_12
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:30:00Z 923.7999999999997 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:31:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:32:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:33:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:34:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:35:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:36:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:37:00Z 923.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:38:00Z 929.1590909090905 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:39:00Z 882.5818181818181 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:40:00Z 870.3999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:41:00Z 870.3999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:42:00Z 870.3999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:43:00Z 879.8142857142855 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:44:00Z 939.8608695652174 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:45:00Z 942.5 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:46:00Z 929.2454545454547 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:47:00Z 890.5304347826087 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:48:00Z 891.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:49:00Z 896.2227272727268 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:50:00Z 896.1166666666671 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:51:00Z 887.2909090909092 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:52:00Z 892 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:53:00Z 896.1125000000003 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:54:00Z 896.9652174 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:55:00Z 896.7999999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:56:00Z 895.8434782608699 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:57:00Z 898.7919999999998 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:58:00Z 898.1000000000001 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T16:59:00Z 898.8272727272728 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:00:00Z 893.3045454545453 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:01:00Z 895.8759999999997 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:02:00Z 903.1130434782611 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:03:00Z 902.2000000000004 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:04:00Z 903.0954545454547 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:05:00Z 907.7260869565217 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:06:00Z 903.4500000000002 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:07:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:08:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:09:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:10:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:11:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:12:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:13:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:14:00Z 901 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:15:00Z 906.7714285714288 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:16:00Z 941.452381 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:17:00Z 942.7142857142857 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:18:00Z 938.6285714285711 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:19:00Z 919.4428571428567 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:20:00Z 917.8666666666668 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:21:00Z 915.9909090909091 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:22:00Z 917.8499999999997 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:23:00Z 917.5363636363635 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:24:00Z 921.2545454545453 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:25:00Z 915.9576923076924 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:26:00Z 915.4642857142859 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:27:00Z 906.1896551724134 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:28:00Z 906.1560000000002 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:29:00Z 904.6259259259258 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:30:00Z 905.1321428571428 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:31:00Z 905.1724137931034 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:32:00Z 902.1571428571428 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:33:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:34:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:35:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:36:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:37:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:38:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:39:00Z 901.8999999999999 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:40:00Z 901.7285714285711 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:41:00Z 900.7500000000002 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:42:00Z 902.8107142857142 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:43:00Z 899.6285714285714 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:44:00Z 898.2481481481481 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:45:00Z 906.0862069 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:46:00Z 903.3107142857143 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:47:00Z 902.5862069 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:48:00Z 904.4541666666664 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:49:00Z 902.2319999999996 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:50:00Z 904.1185185185183 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:51:00Z 902.8482759 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:52:00Z 909.2896552 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:53:00Z 909.3034482758623 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:54:00Z 903.9413793 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:55:00Z 906.5035714285713 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:56:00Z 901.9827586206898 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:57:00Z 903.1714285714285 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
2025-02-17T16:29:17.3176487Z 2025-02-17T22:29:17.3176487Z 2025-02-17T17:58:00Z 901.0565217391301 value weight Heads Mtn Filler 56Aintree Net_Weight_Head_2
thanks for nice sample usable data set. are the 2 queries and 5 transformations and the other set of queries strictly on this sample set of data you provided?
Yes, correct
using the sample data you provided what will the final result(s) you want look like, please also provide this as csv, and what visualization would you like to use? bar chart, time series?
my,final,result
foo,34.4,2025
Thanks for your reply :slight_smile:
I’m struggling to do this in an easy way in this form. In my eyes the data needs to be pivoted to have the tagName as a column. This allows one to get distinct values by comparing the previous. In un-pivoted form there is no point comparing the value to the previous as until it is filtered by tagName.
My thoughts on how I’d do it…
  • Get distinct values per tagName for time period, add up
  • Count values per tagName and add them together to get a total count of all tagName
  • Multiply this count by the ideal weight - in this case 900
  • Compare the total of all tagName and the total of ideal to get a difference
This would just appear as a number using the stat panel.
Would you like me to pivot it and do the calculations?
