Match regex operator broken?
Hello community!
The RegEx expression .* should match anything. While applying this expression in combination with the operator =~ in the New Silence area “Affected alert instances” stays empty. There are definitely alerts firing and these can be matched with the full alertname.
works fine
alertname=FULLALERTNAME
alertname=~FULLALERTNAME
alertname!=WRONGALERTNAME
alertname!~WRONGALERTNAME
do not match
alertname=~.*
alertname=~FULLALERTN.*
Grafana 9.0.2 OSS, Alertmanger 0.24.0
Kind regards
Same issue, Grafana 8.5.9
Any progress? It seams to me that this is still broken in grafana 11 :frowning:
Hi folks! I can’t seem to reproduce this issue on Grafana 11. However, be careful using .* as it also matches missing labels. You want .+.
Facing similar issue for “regex like” silence in grafana, any solution?
