Hi, I have a question… Say I have a 20 Grafana instances (all running on the same server, but on the different port) each of them have about 30-40 dashboards.
I have all dashboards exported as JSON.
When I mass update those JSONs for example 100 files from 5 grafana instances…
Is there a way to mass import them from the server, using some API/command line?
Now I’m just importing them from the UI, but usually changes are small, so importing even 10 dashboards is not that hard, but when I mass update 100 files, iyt would be a life saver to be able to import them automatically somehow…
I was even considering using browser automation/phantomjs scripts to automatic UI clicks, selecting files etc - but I hope there is some better way to do it automatically, avoiding any manual UI work?
There problem occurs when I want to import multiple JSONs on devstats pages:
https://k8s.devstats.cncf.io
Or any other:
*.devstats.cncf.io and *.cncftest.io.
