Making a panel depending on another panel in one dashboard
Hi ,I’m very new to grafana. And I’m wondering whether I can realize something below… A dashboard contains mutiple panels, and one panel is showing some results based on another panel filtering manually by User.
Thanks!
There are some special built in data sources in Grafana. One of them is the --dashboard-- data source:
You can then use Transformations to filter the results:
