Making a call to a gRPC service that includes a bearer token
How do a make a call to a gRPC service that includes a bearer token?
import { check, sleep } from 'k6';
import http from 'k6/http'
const client = new grpc.Client();
client.load(['definitions'], '*.Services.*GrpcService.proto');
export default ()=> {
    client.connect('url.*:5050', {
const data = {
    "*List": [ '*', '*' ],
const response = client.invoke('Package.Service/Method', data);
check(response, {
    'status is OK': (r) => r && r.status === grpc.StatusOK,
  console.log(JSON.stringify(response.message));
  client.close();
  sleep(1);
Hi @jbx
Maybe this example will help you:
import grpc from 'k6/net/grpc';
import { check } from 'k6';
client.load([], 'authorization.proto', 'route_guide.proto');
export function setup() {
  client.connect('auth.googleapis.com:443');
  const resp = client.invoke('google.cloud.authorization.v1.AuthService/GetAccessToken', {
    username: 'john.smith@k6.io',
    password: 'its-a-secret',
  client.close();
  return resp.message.accessToken;
export default (token) => {
  client.connect('route.googleapis.com:443');
  const headers = {
    authorization: `bearer ${token}`,
    'google.cloud.route.v1.RoutingService/GetFeature',
      latitude: 410248224,
      longitude: -747127767,
    { headers }
  check(response, { 'status is OK': (r) => r && r.status === grpc.StatusOK });
  client.close();
Thank you, the tests I’m working with use clientId and clientSecret to get the bearer token. I have this working for 1 test.
export function Token(){
    let url = 'https://auth.dev.pollos-hermanos.cloud/oauth/token';
    const requestBody = {
    client_id: 'ebVDxQfxlWTsGxzpmECrap',
    client_secret: 'PkngambNrwyEpeChuPoJMgzQnnbWxHIUwRPCPYQVqhuA',
    scope: 'pollos:hermanos',
    grant_type: 'client_credentials',
    audience: 'https://api.dev.pollos-hermanos.cloud/public'
const response = http.post(url, requestBody);
console.log('bearerToken success');
return response.json();
the token is then added to params
const token = Token().access_token;
const params = {
  headers: {
    'Content-Type': 'application/json',
    'Authorization': `Bearer ${token}`,
And then passed into the grpc invoke
const response = client.invoke('Pollos.Hermanos.Contracts.v1.Services.PollosService/GetPollosById', data, params);
