I want to write lucene query with field like - Full Name:$name
but it’s not acceptable because it contain white space between field (Full Name)
any solution for this one.
Use quotes around variable name in license query
it won’t work see below error message.
“Failed to parse query [“Resident Name”:(“ravi\ gadhadharia” OR “robert\ downey” OR “rushabh\ prajapati” OR “william\ cina”)]”,
i already try this and (Resident Name):$resident also
If you use multi value variable you do not need to quote grafana with do that for you
Yes, that should be no problem, works fine for me, grafana will escape the white space or quote the value depending on the multi value option for your variable.
Check the elasticsearch metrics dashboard on play.grafana.org
