Lost historical data
    Grafana V9.0.1 and CentOS 7
    Trying to get historical data more than 14 days.
    suddenly lost the data more than 14 days.
  • What happened?
    Previously we were able to see all historical data but not more than 14 days.
    Expect to see historical data through dashboards more than 14 days.
    No
    No
    No.
Regards,
Kaps
  1. What is your data source?
  2. Does your data source contain data older than 14 days (check this
    independently of Grafana)?
Antony.
hello,
it’s look likes it’s related to influxdb database, not really grafana, what is your version of influx ?
did you upgrade, change config or something like that recently ?
I already have dataloss one time with influxdb, it was miss configuration in the virtual machine. it corrupted his volume himself by writting on it (something to see with dynamical, disk memory allocation and other weird limitation)
actually not the database solution fault.
    pulling data from prometheus and DB as influxdb
    how to confirm it?
go on the influxdb interface and try your query,
check the data retention policy on your bucket too
you can query directly influxdb from grafana . did you try it ?
what is influxdb version ?
InfluxDB v1:
#order-by-time-desc
InfluxDB v2:
InfluxDB v2 using v1 query language:
Antony.
influxd version
InfluxDB v1.8.10 (git: 1.8 688e697c51fd)
Hi Team,
Updated /etc/systemd/system/prometheus.service as well but still no luck.
cat /etc/systemd/system/prometheus.service | grep retention
–storage.tsdb.retention.time=1y
Or else it will start keep retention data from now onwords after doing above steps?
Regards,
Kaps
