Hello
I’m trying to make a dashboard with data export from a Prometheus server for pdu apc 8886.But i can’t find a dashboard in grafana database.
I wanna know if someone has already did it and had it in format JSON that i can use please.
Thanks,
Hello
Thanks,
Hello
and welcome to the forum, @reivaxg
I don’t think anyone has done this yet, but people have used snmp to hook up earlier versions. Some research:
Hello, first thanks you for your answer but unfortunately i have already check this website.And i already hook using snmp to my Prometheus server.I just need a dashboard because the one you send to me is not compatible with apc pdu 8xxx.
Thanks again,
did you ever figure this out?
Did you try what @anon70503803 already posted?
Hi All, do you have guys a json file to create a Grafana dashboard for APC PDU 8xxxx
