Looking for a Golang SDK for HTTP API
Note, I’m new here so not allowed to post more than 2 supporting links needed. For reference I’ll just use this, gist if any links are needed. All links. · GitHub
I’ve been developing a CLI tool that allows basic CRUD operations for Grafana.
To avoid re-writing and re-inventing the wheel I’d love to find some Toolkit provided that makes live easier but I keep running into limitations.
  1. grafana-tools SDK. Low traction and seems very slow moving to get anything updated. It’s missing key features that I keep running into but it worked initially for my needs.
  2. I was going to migrate to using: GH: grafana/grafana-api-golang-client, I even made a PR for the initial API integration. It also seems to be pretty sparse and limited. I don’t see way to open issues for it, and as it calls out on the main page, it’s primarily intended for use for the terraform grafana plugin.
  3. I was really excited when I saw Grafana adopt Swagger tooling, and the main repo has the Swagger spec checked in for convenience: GH: grafana/grafana/blob/main/public/api-merged.json, and been trying to keep track of an effort to use the Swagger API. There’s a ticket open for about a year now: GH: Issue: 47827 to generate clients based on the spec.
You can find the initial work here: GH: grafana/grafana-api-golang-client/tree/papagian/generate-client-from-swagger.
I was trying to avoid forking off and managing my own but maybe I missed something?
I took the code written by papagian a year or so ago and re-updated to the latest and checked into: GitHub - esnet/grafana-swagger-api-golang. I would like to avoid it, but it feels like Swagger CodeGen would be the most straight forward path unless someone knows of any alternatives that I missed?
All versions
Find a maintained more feature complete GoLang SDK for the HTTP API.
Use it.
  • What happened?
All competing products are not complete and missing features.
To be complete and provide features.
NA
NA
