Im trying to set up a (very) minimal Loki/Grafana docker installation with MinIO as storage backend.
What’s unusual about my set up is that logs aren’t collected with promtail/alloy but pushed directly to Loki api using /loki/api/v1/push endpoint with json body.
I discovered that most of the time (but not always) after rebooting the containers with docker-compose down; docker-compose up -d I would lose the pushed logs. Inspecting MinIO web console let me to discover no objects would be created in the loki-data bucket aside from loki_cluster_seed.json.
What is puzzling me is that sometimes logs would get persisted, but I cant find any documentation on what is the trigger for flusing them to s3 backend. Is it log age, size? How do I adjust these settings?
My docker-compose.yaml:
networks:
loki:
services:
loki:
image: grafana/loki:3.4.1
restart: unless-stopped
command: "-config.file=/etc/loki/config.yaml"
ports:
- "3100:3100"
volumes:
- "./loki-config.yaml:/etc/loki/config.yaml"
depends_on:
- minio
healthcheck:
test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://localhost:3100/ready || exit 1" ]
interval: 10s
timeout: 5s
retries: 5
networks:
- loki
minio:
image: minio/minio
entrypoint:
- sh
- -euc
mkdir -p /data/loki-data && \
mkdir -p /data/loki-ruler && \
minio server /data --console-address ":9001"
environment:
- MINIO_ROOT_USER=loki
- MINIO_ROOT_PASSWORD=supersecret
- MINIO_PROMETHEUS_AUTH_TYPE=public
- MINIO_UPDATE=off
ports:
- 9000
- "9001:9001"
volumes:
- "./data/minio:/data"
healthcheck:
test: [ "CMD", "curl", "-f", "http://localhost:9000/minio/health/live" ]
interval: 15s
timeout: 20s
retries: 5
networks:
- loki
grafana:
image: grafana/grafana-oss
environment:
- GF_PATHS_PROVISIONING=/etc/grafana/provisioning
entrypoint:
- sh
- -euc
mkdir -p /etc/grafana/provisioning/datasources
cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
apiVersion: 1
datasources:
- name: Loki
type: loki
access: proxy
url: http://loki:3100
EOF
/run.sh
user: "root"
volumes:
- "./data/grafana:/var/lib/grafana"
ports:
- "3000:3000"
healthcheck:
test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://localhost:3000/api/health || exit 1" ]
interval: 10s
timeout: 5s
retries: 5
networks:
- loki
loki-config.yaml
auth_enabled: false
server:
http_listen_address: 0.0.0.0
http_listen_port: 3100
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
limits_config:
discover_log_levels: false
common:
path_prefix: /loki
replication_factor: 1
storage:
s3:
endpoint: minio:9000
insecure: true
bucketnames: loki-data
access_key_id: loki
secret_access_key: supersecret
s3forcepathstyle: true
ring:
kvstore:
store: memberlist
ruler:
storage:
s3:
bucketnames: loki-ruler
