Loki keep complaining about space issue, how could be fix this filling up space. Error: rpc error: code = Unknown desc = mkdir /loki/boltdb-cache/loki_index_19327: no space left on device
Hi @mmallikarjuna ,
This answer is a bit late but maybe it will help someone. This was possibly caused by having /loki on a read-only filesystem. If this is for some sort of container runtime platform like e.g. Kubernetes, then you could mount an empty volume at /loki and that should allow for the folder to be created.
Example from my setup
Here you can see the working-directory set
containers:
- name: compactor
image: docker.io/grafana/loki:2.7.3
imagePullPolicy: IfNotPresent
args:
- -config.file=/etc/loki/config/config.yaml
- -target=compactor
- -boltdb.shipper.compactor.working-directory=/var/loki/compactor
- -config.expand-env=true
I add this to make the folder usable
volumeMounts:
- name: data
mountPath: /var/loki
volumes:
- name: data
persistentVolumeClaim:
claimName: data-loki-distributed-compactor
Just realised that uses a pvc but it would be very similar with non-persistent storage
volumeMounts:
- name: data
- name: data
emptyDir: {}
Hope that helps ![]()
