Loki 3.0 configuration
Hi.
Please tell me, I switched to the grafana/loki version:3.0.0
wrote such a config, disk space is running out and there is no cleanup.
What settings are missing?
auth_enabled: false
server:
  http_listen_port: 3100
common:
  instance_addr: 127.0.0.1
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
query_range:
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 100
schema_config:
  configs:
      store: tsdb
      object_store: filesystem
      schema: v13
      index:
        prefix: index_
        period: 24h
table_manager:
  retention_deletes_enabled: true
  retention_period: 10m
limits_config:
  retention_period: 168h
  max_query_lookback: 168h
compactor:
  working_directory: /tmp/loki/compactor
  compaction_interval: 10m
  retention_enabled: true
  retention_delete_delay: 2h
  retention_delete_worker_count: 150
  delete_request_store: filesystem
ruler:
  alertmanager_url: http://alertmanager:9093
Try disabling table_manager. See Log retention | Grafana Loki documentation.
