Grafana v9.1.2 on windows server 2016 and Loki v2.9.1 on windows server 2008 r2
What are you trying to achieve? Consistent logs and dasboards
How are you trying to achieve it? by sending logs from promtail to loki and visualize them on grafana by consuming loki datasource
What happened? The issue I introduced labels by using regex on promtail yaml config but they are only showing on specific date ranges but not on all or quick ranges
What did you expect to happen? the labels should be there all the time
Can you copy/paste the configuration(s) that you are having problems with? yes indeed
Loki Config:
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 1024
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
Statistics help us better understand how Loki is used, and they show us performance
levels for most users. This helps us prioritize features and documentation.
For more information on what’s sent, look at
https://github.com/grafana/loki/blob/main/pkg/usagestats/stats.go
Refer to the buildReport method to see what goes into a report.
If you would like to disable reporting, uncomment the following lines:
#analytics:
reporting_enabled: false
Promtail config:
server:
http_listen_port: 9080
http_listen_address: 0.0.0.0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://localhost:3100/loki/api/v1/push
external_labels:
job: iis-logs
scrape_configs:
- job_name: iis-logs
pipeline_stages:- regex:
expression: ‘^(?P<s_port>\d+) (?P<c_ip>[^ ]+) (?P[^ ]+) (?P<cs_username>[^ ]+) (?P<cs_uri_query>[^“]) “(?P<cs_Referer>[^”])” (?P<cs_method>GET|POST|PUT|PATCH|DELETE) “(?P<cs_User_Agent>[^”])" (?P<sc_win32_status>\d+) (?P<sc_status>\d+) “(?P<X_Forwarded_For>[^”])" (?P<s_ip>[^ ]+) (?P[^ ]+) (?P[^ ]+) “(?P<cs_uri_stem>[^”])" “(?P<s_sitename>[^”])"’ - labels:
s_port: s_port
c_ip: c_ip
TimeTakenMS: TimeTakenMS
cs_username: cs_username
cs_uri_query: cs_uri_query
cs_Referer: cs_Referer
cs_method: cs_method
cs_User_Agent: cs_User_Agent
sc_win32_status: sc_win32_status
sc_status: sc_status
X_Forwarded_For: X_Forwarded_For
s_ip: s_ip
time: time
date: date
cs_uri_stem: cs_uri_stem
s_sitename: s_sitename
static_configs: - targets: [‘localhost’]
labels:
job: iis-logs
path: ‘C:/inetpub/logs/AdvancedLogs/*’
- regex:
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No not an error just label are not showing
- Did you follow any online instructions? If so, what is the URL?
No I didn’t mostly on my own.
