Loki Retention Not Working (Simple Scalable)
My Loki cluster is not respecting my log retention settings and is storing the logs indefinitely.
My config:
Loki version 3.5.5
target: read
auth_enabled: true
common:
compactor_address: http://localhost:9443
replication_factor: 3
ring:
heartbeat_timeout: 10m
kvstore:
store: memberlist
compactor:
compaction_interval: 1m
delete_request_store: s3
retention_enabled: true
working_directory: /loki/compactor
frontend:
compress_responses: true
log_queries_longer_than: 15s
frontend_worker:
frontend_address: test.frontend.loki.it.ufl.edu:9443
grpc_client_config:
max_send_msg_size: 104857600.0
ingester:
chunk_idle_period: 1h
flush_check_period: 10s
max_chunk_age: 2h
wal:
replay_memory_ceiling: 6047MB
limits_config:
allow_structured_metadata: false
bloom_gateway_enable_filtering: true
ingestion_burst_size_mb: 60
ingestion_rate_mb: 40
max_cache_freshness_per_query: 10m
max_entries_limit_per_query: 100000
max_global_streams_per_user: 20000
max_query_parallelism: 6
max_query_series: 10000
per_stream_rate_limit: 40MB
per_stream_rate_limit_burst: 60MB
query_timeout: 3m
reject_old_samples: true
retention_period: 48h
split_queries_by_interval: 15m
memberlist:
abort_if_cluster_join_fails: false
bind_port: 7946
join_members:
  • az1-ict-o11y-test-loki-read-pve-1.server
  • az1-ict-o11y-test-loki-read-pve-4.server
  • az1-ict-o11y-test-loki-read-pve-2.server
  • az1-ict-o11y-test-loki-read-pve-3.server
  • az2-ict-o11y-test-loki-read-pve-1.server
  • az2-ict-o11y-test-loki-read-pve-2.server
  • az2-ict-o11y-test-loki-read-pve-3.server
  • az1-ict-o11y-test-loki-write-pve-1.server
  • az1-ict-o11y-test-loki-write-pve-2.server
  • az1-ict-o11y-test-loki-write-pve-3.server
  • az2-ict-o11y-test-loki-write-pve-1.server
  • az2-ict-o11y-test-loki-write-pve-2.server
    max_join_backoff: 1m
    max_join_retries: 10
    min_join_backoff: 1s
    rejoin_interval: 1m
    querier:
    max_concurrent: 6000
    multi_tenant_queries_enabled: true
    query_range:
    align_queries_with_step: true
    cache_results: true
    max_retries: 5
    results_cache:
    cache:
    embedded_cache:
    enabled: true
    max_size_mb: 2048
    ttl: 1h
    query_scheduler:
    max_outstanding_requests_per_tenant: 42768
    schema_config:
    configs:
    index:
    period: 24h
    prefix: index_tsdb_
    object_store: aws
    schema: v13
    store: tsdb
    server:
    grpc_listen_port: 9443
    grpc_server_max_concurrent_streams: 1500
    grpc_server_max_recv_msg_size: 104857600
    grpc_server_max_send_msg_size: 104857600
    http_listen_port: 8443
    http_server_read_timeout: 610s
    http_server_write_timeout: 610s
    http_tls_config:
    cert_file: /etc/loki/ssl/cert.crt
    key_file: /etc/loki/ssl/cert.key
    log_level: info
    storage_config:
    aws:
    access_key_id: OMITTED
    bucketnames: irs-loki-test
    endpoint: ict-mc2-oss02.server.ufl.edu
    http_config:
    insecure_skip_verify: true
    insecure: false
    region: default
    s3forcepathstyle: true
    secret_access_key: OMITTED
    hedging:
    at: 250ms
    max_per_second: 20
    up_to: 3
    tsdb_shipper:
    active_index_directory: /loki/tsdb-shipper-active
    cache_location: /loki/tsdb-shipper-cache
Any help is greatly appreciated!
I fixed this by deploying dedicated compactor nodes.
Can you elaborate a bit on this?
Do you move to distributed mode to deploy dedicated compactor nodes?
