Currently im noticed that I have some missing log entries in Loki. Im currently using the OTLP endpoint with an otel-contrib collector infront of it.
Im also sending the logs to another otlp endpoint in the same pipeline but that backend has all the logs, but in loki which i currently preferer im missing some.
Did anyone also encounter this problem?
This is my loki configuration, its mostly basic changes.
auth_enabled: true # enables multi tenancy
server:
http_listen_port: 3100
log_level: info
common:
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
replication_factor: 1
path_prefix: /loki
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
compactor:
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
delete_request_store: s3
limits_config:
max_query_lookback: 672h # 28 days
retention_period: 672h # 28 days
storage_config:
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
cache_ttl: 24h
aws:
s3: minio
s3forcepathstyle: true
Thanks.
