Hello together,
i have installed Loki and Promtail on my OpenShift 3.9 cluster.
I use this Promtail ConfigMap:
# Client Config clients: - url: http://loki.grafana-test.svc:3100/loki/api/v1/push # Server Config server: http_listen_port: 9080 grpc_listen_port: 0 log_level: debug positions: filename: /tmp/positions.yaml scrape_configs: - job_name: system entry_parser: raw static_configs: - targets: - localhost labels: job: varlogs __path__: /var/log/*log
So far it works like expected. I can see the logs from the Promtail Pod itself in my Grafana.
Now I like to scrap the Logs from a single Pod “Pod-A”.
Is this possible with Loki on OpenShift 3.9?
Thanks in advance
