docker-compose.yaml context
init-loki:
profiles:
- init
image: ubuntu
user: root
# command: chown -R 10001:10001 /data/loki
command: chown -R 1031:100 /data/loki #
volumes:
- ./loki/data:/data/loki
loki:
image: grafana/loki:2.9.3
restart: unless-stopped
user: 1031:100
environment:
- TC=UTC
volumes:
# - /etc/timezone:/etc/timezone:ro
# - /etc/localtime:/etc/localtime:ro
- ./loki/loki.yaml:/etc/loki/loki.yaml:ro
command:
- --config.file=/etc/loki/loki.yaml
- --log.level=debug
# - --config.expand-env=true
ports:
- 3100:3100
- 9096:9096
- 7946:7946
loki.yaml
analytics:
reporting_enabled: false
auth_enabled: false
server:
http_listen_port: 3100
ingester:
wal:
enabled: false
# lifecycler:
# address: nas.lan
# ring:
# kvstore:
# store: inmemory
# replication_factor: 1
# query_range:
# results_cache:
# cache:
# embedded_cache:
# enabled: true
# max_size_mb: 100
schema_config:
configs:
store: tsdb
# store: boltdb
object_store: filesystem
schema: v12
index:
prefix: index_
period: 24h
storage_config:
filesystem:
directory: /data/loki/filesystem
tsdb_shipper:
active_index_directory: /data/loki/tsdb-index
cache_location: /data/loki/tsdb-cache
# shared_store: filesystem
loki_1 | mkdir : no such file or directory
loki_1 | error initialising module: compactor
loki_1 | github.com/grafana/dskit/modules.(*Manager).initModule
loki_1 | /src/loki/vendor/github.com/grafana/dskit/modules/modules.go:138
loki_1 | github.com/grafana/dskit/modules.(*Manager).InitModuleServices
loki_1 | /src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108
loki_1 | github.com/grafana/loki/pkg/loki.(*Loki).Run
loki_1 | /src/loki/pkg/loki/loki.go:461
loki_1 | main.main
loki_1 | /src/loki/cmd/loki/main.go:110
loki_1 | runtime.main
loki_1 | /usr/local/go/src/runtime/proc.go:267
loki_1 | runtime.goexit
loki_1 | /usr/local/go/src/runtime/asm_amd64.s:1650
No info what directory. I have tried multiple variants, but it doesn’t work.
How to fix this? Error message is not helpful.
How to make the right config config for NAS Synology? This imply data are already mirrored and also I don’t care about losing logs, because of hardware failure.
