Summary
What am I doing
Deleting logs from Loki via compactor API endpoint
What I want to achieve
Delete logs based on stream and line filters
My current results
I can only delete logs based on stream filters, but not line
Loki version: 2.6.1
Details
Hello!
I have a quite big deployment of Loki with almost all components, for storage I use S3. From time to time, I need to delete some logs that match specific streams and line filters. Whenever I include line filters in a query Loki does not delete any of the logs. I’ll share more details below.
Configurations
Relevant part of Loki config
common:
compactor_address: loki-distributed-compactor.loki.svc.cluster.local:3100
compactor:
compaction_interval: 10m
delete_request_cancel_period: 15m
deletion_mode: filter-and-delete
retention_delete_delay: 2h
retention_enabled: true
shared_store: s3
ingester:
chunk_idle_period: 30m
chunk_retain_period: 1m
query_range:
cache_results: true
results_cache:
cache:
enable_fifocache: false
memcached_client:
addresses: dns+loki-distributed-memcached-frontend.loki.svc.cluster.local:11211
storage_config:
boltdb_shipper:
cache_ttl: 24h
shared_store: s3
Relevant part of Overrides config
overrides:
main:
allow_deletes: true
Relevant part of the gateway (Nginx) config
location = /loki/api/v1/delete {
set $loki_api_v1_delete_backend http://loki-distributed-compactor.loki.svc.cluster.local;
proxy_pass $loki_api_v1_delete_backend:3100$request_uri;
proxy_http_version 1.1;
Story
I have a specific service that I trigger to create logs with the label {facility: "archilogen"}, I want to delete logs only containing the message “archilogen-warn”. I first generate logs, then wait for 30m+ (maybe even multiple hours) so chunks become idle and are sent to S3. After this I send the following API request to the compactor:
curl -I -X POST -H 'X-scope-OrgID: main' -g 'http://xxx/loki/api/v1/delete?query={facility="archilogen"}|="archilogen-warn"'
HTTP/1.1 204 No Content
I can see that request was successful:
curl -H 'X-scope-OrgID: main' 'http://xxx:3020/loki/api/v1/delete' | jq '.[] | select(.status=="received")'
"request_id": "7cdae6e5",
"start_time": 0,
"end_time": 1667381172.093,
"query": "{facility=\"archilogen\"}|=\"archilogen-warn\"",
"status": "received",
"created_at": 1667381172.093
Theoretically according to my config they should be deleted in 15m, Yet after many hours, non of the logs are deleted.
On the other hand, if I issue the following request, I’ll definitely see that there are matching logs
curl -H 'X-scope-OrgID: main' -g 'http://xxx:3020/loki/api/v1/query_range?query={facility="archilogen"}|="archilogen-warn"&start=1667281172' | jq
And what’s even more strange, If I set query= parameter to simply {facility="archilogen"} all logs will be deleted within 15-30m
One thing I suspected initially was caching, but in this case similar would happen when using label filters only.
Would you have any suggestions?
