Loki 3.5.0 — /loki/api/v1/delete returns “query not set” even though query works in /query
Hi everyone,
I’m facing an issue with the log delete API in Grafana Loki 3.5.0.
When I use the /loki/api/v1/query endpoint, my queries work perfectly fine.
However, when I try to delete logs using the /loki/api/v1/delete endpoint with the same query, I get the following response:
query not set
Setup Details
  • Loki Version: 3.5.0
  • Deployment: Kubernetes (single binary)
  • Storage Backend: MinIO (S3 compatible)
What Works
:white_check_mark: Querying logs:
curl -G "http://<loki-url>:3100/loki/api/v1/query" \
  --data-urlencode 'query={app="nginx"}'
This returns the expected log results.
What Fails
:cross_mark: Deleting logs:
curl -X POST "http://<loki-url>:3100/loki/api/v1/delete" \
  -H "Content-Type: application/json" \
  -d '{"start":"2025-10-09T00:00:00Z","end":"2025-10-09T23:59:00Z","query":"{app=\"nginx\"}"}'
Response:
query not set
There’s no delete activity or error trace visible in the Loki pod logs.
Expected Behavior
Loki should accept the delete request and return a valid request_id or delete confirmation message.
Actual Behavior
The delete API rejects the request with query not set, even though the same query works for normal querying.
this is my loki config file and I can see the logs in Minio buckets
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9095
  log_level: info
ingester:
  chunk_idle_period: 30s
  chunk_block_size: 262144
  chunk_retain_period: 1m
  wal:
    dir: /data/loki/wal
  lifecycler:
    ring:
      kvstore:
        store: memberlist
      replication_factor: 1
limits_config:
  allow_structured_metadata: false
  deletion_mode: filter-and-delete
  reject_old_samples: true
  max_entries_limit_per_query: 5000
  retention_period: 4380h
  max_query_length: 4380h
  max_query_parallelism: 8
  split_queries_by_interval: 1h
  allow_deletes: true
schema_config:
  configs:
      store: boltdb-shipper
      object_store: s3
      schema: v13
      index:
        prefix: index\_
        period: 24h
storage_config:
  boltdb_shipper:
    active_index_directory: /data/loki/boltdb-shipper-active
    cache_location: /data/loki/boltdb-shipper-cache
    cache_ttl: 24h
  aws:
    endpoint: http://monitoring-minio.monitoring.svc.cluster.local:9000
    bucketnames: protectionlog
    access_key_id: minioadmin
    secret_access_key: minioadmin
    region: us-east-1
    s3forcepathstyle: true
    insecure: true
table_manager:
  retention_deletes_enabled: true
compactor:
  working_directory: /data/loki/boltdb-shipper-compactor
  retention_enabled: true
  delete_request_store: s3
  delete_request_cancel_period: 5m
  retention_delete_delay: 0s
  compaction_interval: 10s
  apply_retention_interval: 10s
@tonyswumac @yosiasz Please help here
Thanks in advance…! let me know if any other information required.
and please confirm Is delete via API supported in 3.5.0, or is there an alternate method to delete logs programmatically?
If not, what’s the recommended way to delete logs via API
I don’t personally use the delete endpoint, so I could be wrong. But perhaps try breaking your URL parts like you did with the query API call? Something like:
  --data-urlencode "start=2025-10-09T00:00:00Z" \
  --data-urlencode "end=2025-10-09T23:59:00Z" \
  --data-urlencode "query={app=\"nginx\"}"
