I am setting up Loki for the first time using loki-distributed and everything works great except for the live tail which is returning:
Query error
Live tailing was stopped due to following error: undefined
If I use logcli with port-forward of the query-frontend I can tail successfully:
logcli query --addr="http://localhost:3100" '{filename="/var/log/pods/monitoring_loki-loki-distributed-ingester-0_d439f9ec-713b-4b62-a8b2-b10cdfea28c5/ingester/0.log"}' --tail
If I check Developer tools I see it is a websocket error:
centrifuge.js:585 WebSocket connection to 'wss://monitoring.mysite.io/api/live/ws' failed:
value @ centrifuge.js:585
WebSocketSubject.js:94 WebSocket connection to 'wss://monitoring.mysite.io/api/datasources/proxy/4/loki/api/v1/tail?query=%7Bnamespace%3D~%22.%2B%22%7D' failed:
t._connectSocket @ WebSocketSubject.js:94
runRequest.ts:147 runRequest.catchError Live tailing was stopped due to following error: undefined
I am installing through Helm with an S3 backend, here is my configuration:
loki:
containerSecurityContext:
readOnlyRootFilesystem: false
# image:
# repository: grafana/loki
# tag: 2.3.0
config: |
auth_enabled: false
server:
log_level: debug
http_listen_port: 3100
memberlist:
randomize_node_name: false
join_members:
- {{ include "loki.fullname" . }}-memberlist.monitoring.svc.cluster.local
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
chunk_idle_period: 30m
chunk_block_size: 262144
chunk_encoding: snappy
chunk_retain_period: 1m
max_transfer_retries: 0
wal:
dir: /var/loki/wal
limits_config:
enforce_metric_name: false
ingestion_burst_size_mb: 20
ingestion_rate_mb: 50
ingestion_rate_strategy: global
max_cache_freshness_per_query: 10m
max_global_streams_per_user: 10000
max_query_length: 12000h
max_query_parallelism: 16
max_streams_per_user: 0
reject_old_samples: true
{{- if .Values.loki.schemaConfig}}
schema_config:
{{- toYaml .Values.loki.schemaConfig | nindent 2}}
{{- end}}
{{- if .Values.loki.storageConfig}}
storage_config:
{{- if .Values.indexGateway.enabled}}
{{- $indexGatewayClient := dict "server_address" (printf "dns:///%s:9095" (include "loki.indexGatewayFullname" .)) }}
{{- $_ := set .Values.loki.storageConfig.boltdb_shipper "index_gateway_client" $indexGatewayClient }}
{{- end}}
{{- toYaml .Values.loki.storageConfig | nindent 2}}
{{- end}}
query_range:
# make queries more cache-able by aligning them with their step intervals
align_queries_with_step: true
max_retries: 5
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 1024
validity: 24h
frontend_worker:
frontend_address: {{ include "loki.queryFrontendFullname" . }}:9095
frontend:
log_queries_longer_than: 5s
compress_responses: true
tail_proxy_url: http://{{ include "loki.querierFullname" . }}:3100
compactor:
working_directory: /data/loki/boltdb-shipper-compactor
shared_store: s3
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
compactor_ring:
kvstore:
store: memberlist
schemaConfig:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: index_
period: 24h
storageConfig:
aws:
s3: s3://us-east-2/mybucket
s3forcepathstyle: true
boltdb_shipper:
active_index_directory: /var/loki/index
shared_store: s3
cache_location: /var/loki/boltdb-cache
cache_ttl: 168h
index_gateway_client:
server_address: dns:///loki-distributed-index-gateway:9095
querier:
replicas: 1
extraVolumes:
- name: bolt-db
emptyDir: {}
extraVolumeMounts:
- name: bolt-db
mountPath: /var/loki
serviceAccount:
create: false
indexGateway:
enabled: true
compactor:
enabled: true
Any help would be greatly appreciated!
