Loki ingester stuck in a loop "uploading tables" and /ready returns 503
Each of our three loki ingester replicas (deployed with the loki helm chart, version 6.53.0) are stuck repeatedly doing this in the logs:
level=info ts=2026-03-10T00:48:24.304438644Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:48:24.304492774Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:48:24.304500563Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:48:24.304506234Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
level=info ts=2026-03-10T00:49:24.305364155Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:49:24.305459955Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:49:24.305468395Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:49:24.305475215Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
level=info ts=2026-03-10T00:50:24.305198007Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:50:24.305278907Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:50:24.305287547Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:50:24.305292807Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
level=info ts=2026-03-10T00:51:24.305112699Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:51:24.305170489Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:51:24.305184389Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:51:24.305191529Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
level=info ts=2026-03-10T00:52:24.304367141Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:52:24.304461561Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:52:24.304473311Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:52:24.304481031Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
level=info ts=2026-03-10T00:53:24.304373023Z caller=table_manager.go:136 index-store=tsdb-2025-03-04 msg="uploading tables"
level=info ts=2026-03-10T00:53:24.304443403Z caller=index_set.go:86 msg="uploading table loki_index_20521"
level=info ts=2026-03-10T00:53:24.304451593Z caller=index_set.go:107 msg="finished uploading table loki_index_20521"
level=info ts=2026-03-10T00:53:24.304460383Z caller=index_set.go:186 msg="cleaning up unwanted indexes from table loki_index_20521"
When we hit /ready we see
Some services are not Running:
Starting: 1
Running: 6
And it returns a 503
/services returns:
runtime-config => Running
server => Running
memberlist-kv => Running
ring => Running
store => Running
analytics => Running
ingester => Starting
Not sure how to get the ingester to mark itself ready, has anyone run into this before or have any tips we could try?
  1. Can you share your loki configuration please?
  2. Can you see if you can find the actual error logs? Maybe when services are attempting to start? Also enable debug and see what you can find. These repeating logs aren’t very helpful.
