Loki full CPU for a long time and need restart to work again
Hi, random times i get full CPU for a long time and every stop working, i need to restart loki to work. IT was full for 15 min before restart container.
I have one container only, with boltdb and S3.
Any idea what i need to search to find the issue? Or maybe why is happening?
What is your log volume looking like? Perhaps it’s time to look into simple scalable deployment.
But if you want to just run a single instance, I’d recommend you to try and reduce the number of chunks written to S3, and avoid splitting query too much.
how can i find my volume?
Is to small maybe a 5-6 GB per day. Now is one EC2 with 8 CPU, i am planning to have a small scalable but i cannot now :frowning: but i need to find the issue with this but no luck :confused:
Average per day is ~25% CPU and some spikes to 50-60%.
  1. Check your storage and see how many files you have a day. If you are running a single instance I’d try to aim for having as few files as possible.
  2. Reduce query split.
hi Tony, thank you for your reply :slight_smile:
  1. storage files:
    from S3 bucket metrics: 30000 (not sure how i can check from loki metrics)
How can you have fewer files? delete the old?
  1. Reduce query split.
I will try change this (not sure if is this )
limits_config:
split_queries_by_interval
There are a couple of configurations that you can use to control how many chunks get written, such as max_chunk_age, chunk_idle_period, and chunk_target_size. Make sure to also adjust query_ingesters_within to match.
As for splitting queries, split_queries_by_interval is what you want. You can change that to 12h or 24h for example and see how it performs.
