I am trying to run my k6 script locally however send all the data to my free grafana cloud account. Unfortunately when i run my script i get the below error. What also happens is that when i look at my cloud account i can see that the test was created but then it times out waiting for the data to be sent.
if i remove the --local-execution part of the command, it runs in the cloud fine. If i just use k6 run without the cloud part of the command it runs fine.
The command i use is:
k6 cloud run --local-execution scripts/script_signing_copy.js
The terminal output i get is:
goroutine 133 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x6?, 0xb0?, 0xc000a0a750?)
runtime/sema.go:95 +0x25
sync.(*Mutex).lockSlow(0xc0007aa534)
sync/mutex.go:173 +0x15d
sync.(*Mutex).Lock(...)
sync/mutex.go:92
sync.(*Once).doSlow(0xc000a0a750?, 0xc000a0a738)
sync/once.go:72 +0x50
sync.(*Once).Do(...)
sync/once.go:67
github.com/grafana/sobek.(*SourceTextModuleRecord).InitializeEnvironment(0x19c7cc0?)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:542 +0x49
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc0001ee460, 0xc000a0a880, {0x1ff6a60?, 0xc000794780}, 0xc000a0a868, 0x0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules.go:112 +0x48f
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc0001ee460, {0x1ff6a60, 0xc000794780})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules.go:71 +0x1bd
github.com/grafana/sobek.(*SourceTextModuleRecord).Link(0xc000794780)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:668 +0xbb
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0003ac300, 0xc00030e7b0)
go.k6.io/k6/js/modules/resolution.go:247 +0x102
go.k6.io/k6/js.(*Bundle).instantiate.func3()
go.k6.io/k6/js/bundle.go:338 +0x27
reflect.Value.call({0x1932280?, 0xc0003acbc0?, 0xc000a2dc20?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000a0b288?})
reflect/value.go:581 +0xca6
reflect.Value.Call({0x1932280?, 0xc0003acbc0?, 0xc0003acbe0?}, {0x306b440?, 0x120?, 0x35554aaaa?})
reflect/value.go:365 +0xb9
github.com/grafana/sobek.(*Runtime).newWrappedFunc.(*Runtime).wrapReflectFunc.func1({{0x0, 0x0}, {0x0, 0x0, 0x0}})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:2029 +0x3bd
github.com/grafana/sobek.AssertFunction.func1.1()
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:2464 +0x56
github.com/grafana/sobek.(*vm).try(0xc000b8c120, 0xc000a0b5a8)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:863 +0x249
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000b86408, 0xc0008ea0b0?)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:2508 +0x65
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0008ea0a8?})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:2463 +0x8c
go.k6.io/k6/js.(*Bundle).instantiate.func4()
go.k6.io/k6/js/bundle.go:345 +0x23
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000b9a140, 0xc00079a900)
go.k6.io/k6/js/eventloop/eventloop.go:177 +0x19a
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000b8e400, 0x14)
go.k6.io/k6/js/bundle.go:344 +0x390
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x14)
go.k6.io/k6/js/bundle.go:257 +0x1f1
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x14, 0x14, 0xc0001fc620)
go.k6.io/k6/js/runner.go:128 +0x58
go.k6.io/k6/js.(*Runner).NewVU(0xc000788180?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
go.k6.io/k6/js/runner.go:116 +0x1d
go.k6.io/k6/execution.(*Scheduler).initVU(0xc000561a00, {0x1ff6668, 0xc0002627d0}, 0xc0001fc620, {0x2011b60, 0xc0003019d0})
go.k6.io/k6/execution/scheduler.go:133 +0x9f
go.k6.io/k6/execution.(*Scheduler).initVUsConcurrently.func1()
go.k6.io/k6/execution/scheduler.go:172 +0xd2
created by go.k6.io/k6/execution.(*Scheduler).initVUsConcurrently in goroutine 1
go.k6.io/k6/execution/scheduler.go:170 +0x97
goroutine 134 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x5?, 0x0?, 0xc00006a750?)
sync/mutex.go:92
sync.(*Once).doSlow(0xc00006a750?, 0xc00006a738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc00023a1c0, 0xc00006a880, {0x1ff6a60?, 0xc000794780}, 0xc00006a868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc00023a1c0, {0x1ff6a60, 0xc000794780})
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0006ec560, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc0006ec9a0?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc00006b288?})
reflect.Value.Call({0x1932280?, 0xc0006ec9a0?, 0xc0006ec9c0?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc00002a000, 0xc00006b5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc0003b3408, 0xc000792120?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0007920f8?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc00070e000, 0xc000900630)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc0004f60c0, 0x18)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x18)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x18, 0x18, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de3c0?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 135 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x4?, 0xc0?, 0xc0004b2750?)
sync.(*Mutex).lockSlow(0xc00083a094)
sync/mutex.go:92
sync.(*Once).doSlow(0xc0004b2750?, 0xc0004b2738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc00023a690, 0xc0004b2880, {0x1ff6a60?, 0xc000d34d20}, 0xc0004b2868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc00023a690, {0x1ff6a60, 0xc000d34d20})
github.com/grafana/sobek.(*SourceTextModuleRecord).Link(0xc000d34d20)
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0006ecc80, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc0006ed000?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc0004b3288?})
reflect.Value.Call({0x1932280?, 0xc0006ed000?, 0xc0006ed020?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc000cb8b40, 0xc0004b35a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc0008e0808, 0xc000792248?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0007921f8?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc00070e8c0, 0xc000900f90)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc0004f65c0, 0x16)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x16)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x16, 0x16, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de360?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 136 [runnable]:
github.com/grafana/sobek.(*baseObject)._put(0xc000cb3500, {0x1c77388, 0x6}, {0x200b3f0, 0xc000cb3568})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/object.go:788 +0x165
github.com/grafana/sobek.(*baseFuncObject).init(0xc000cb3500, {0x21fa2c5, 0x43}, {0x200b948, 0x2dee8e8})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/func.go:507 +0xb6
github.com/grafana/sobek.(*Runtime).newWrappedFunc(0xc000c88408, {0x1961cc0?, 0xc000e0cc00?, 0xc000cd2290?})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:786 +0x298
github.com/grafana/sobek.(*Runtime).toValue(0xc000c88408, {0x1961cc0, 0xc000e0cc00}, {0x0?, 0x0?, 0x40?})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:1966 +0x1229
github.com/grafana/sobek.(*Runtime).ToValue(...)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:1792
github.com/grafana/sobek.initIndirect.exec({0x8?, 0xc000e0cc00?}, 0xc000c90000)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:2954 +0x59
github.com/grafana/sobek.(*vm).run(0xc000c90000)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:635 +0x5b
github.com/grafana/sobek.(*vm).runTryInner(0xc000cd2490?)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:886 +0x52
github.com/grafana/sobek.(*generator).step(0xc000267b20)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/func.go:762 +0x2b
github.com/grafana/sobek.(*asyncRunner).start(0xc000267b20, 0x0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/func.go:733 +0xfd
github.com/grafana/sobek.(*baseJsFuncObject).asyncVmCall(0xc000cb3080, 0xc000c90000, 0x0, 0xc0007b5ea0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/func.go:664 +0x79
github.com/grafana/sobek.(*asyncFuncObject).vmCall(0xc000cb3080, 0xc000c90000, 0x0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/func.go:670 +0x65
github.com/grafana/sobek.call.exec(0xb03c00?, 0xc000c90000)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:3719 +0x66
github.com/grafana/sobek.(*vm).runTryInner(0xc000c92080?)
github.com/grafana/sobek.(*vm).runTry(0xc000c90000)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/vm.go:872 +0x1e5
github.com/grafana/sobek.(*Runtime).RunProgram(0xc000c88408, 0xc000b3e9c0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/runtime.go:1481 +0x43c
github.com/grafana/sobek.(*SourceTextModuleRecord).Instantiate(0xc000cb7360, 0xc000c88408)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:651 +0x205
github.com/grafana/sobek.(*Runtime).innerModuleEvaluation(0xc000c88408, 0xc000c96230, {0x1ff6a60, 0xc000cb7360}, 0xc000cd2a98, 0x0, 0xc000cd2c18)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules.go:224 +0x18f
github.com/grafana/sobek.(*Runtime).CyclicModuleRecordEvaluate(0xc000c88408, {0x1fff020, 0xc000cb7360}, 0xc000cd2c18)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules.go:183 +0x47d
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc000cac140, 0xc00030e7b0)
go.k6.io/k6/js/modules/resolution.go:255 +0x1c8
reflect.Value.call({0x1932280?, 0xc000cac4c0?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000c9f288?})
reflect.Value.Call({0x1932280?, 0xc000cac4c0?, 0xc000cac4e0?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc000c90000, 0xc000c9f5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000c88408, 0xc000cae058?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc000cae050?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000c96000, 0xc000626700)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000c92040, 0xd)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0xd)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0xd, 0xd, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de480?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 137 [runnable]:
github.com/grafana/sobek.importEntriesFromAst({0xc0008f6980, 0x9, 0x10?})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:118 +0x9d9
github.com/grafana/sobek.ModuleFromAST(0xc00022e310, 0xc0005f3820)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:381 +0x79
go.k6.io/k6/js/modules.(*ModuleResolver).resolveLoaded(0xc000127770, 0xc00073cc28?, {0xc0008fa000?, 0xc0003ffbc0?}, {0xc000390000, 0x2901, 0x0?})
go.k6.io/k6/js/modules/resolution.go:124 +0x20d
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0006ec140, 0xc00030e7b0)
go.k6.io/k6/js/modules/resolution.go:239 +0xbb
reflect.Value.call({0x1932280?, 0xc0006ec4c0?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc00073d288?})
reflect.Value.Call({0x1932280?, 0xc0006ec4c0?, 0xc0006ec4e0?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc0000270e0, 0xc00073d5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc0008e0008, 0xc0008ea058?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0008ea050?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000242370, 0xc00050c700)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc0005fe040, 0x3)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x3)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x3, 0x3, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de420?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 138 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x3?, 0xd0?, 0xc000b0a750?)
sync/mutex.go:92
sync.(*Once).doSlow(0xc000b0a750?, 0xc000b0a738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc000bb22a0, 0xc000b0a880, {0x1ff6a60?, 0xc000794780}, 0xc000b0a868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc000bb22a0, {0x1ff6a60, 0xc000794780})
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0007501a0, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc0007505e0?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000b0b288?})
reflect.Value.Call({0x1932280?, 0xc0007505e0?, 0xc000750600?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc00018a000, 0xc000b0b5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000a80008, 0xc00069a188?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc00069a168?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000a86000, 0xc00050c9a0)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc0006e8080, 0x7)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x7)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x7, 0x7, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de4e0?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 139 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x4?, 0xd0?, 0xc00095e750?)
sync/mutex.go:92
sync.(*Once).doSlow(0xc00095e750?, 0xc00095e738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc00077c0e0, 0xc00095e880, {0x1ff6a60?, 0xc000794780}, 0xc00095e868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc00077c0e0, {0x1ff6a60, 0xc000794780})
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc000da6140, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc000b1d340?, 0xc0009ce480?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc00095f288?})
reflect.Value.Call({0x1932280?, 0xc000b1d340?, 0xc000b1d360?}, {0x306b440?, 0x120?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc000d90120, 0xc00095f5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000d8a408, 0xc000cae200?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc000cae1f8?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000d96050, 0xc0005bd210)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000d920c0, 0x11)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x11)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x11, 0x11, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de540?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 140 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x5?, 0xa0?, 0xc000d18750?)
sync.(*Mutex).lockSlow(0xc000d1e144)
sync/mutex.go:92
sync.(*Once).doSlow(0xc000d18750?, 0xc000d18738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc000bb2620, 0xc000d18880, {0x1ff6a60?, 0xc000798140}, 0xc000d18868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc000bb2620, {0x1ff6a60, 0xc000798140})
github.com/grafana/sobek.(*SourceTextModuleRecord).Link(0xc000798140)
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc000d2aa80, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc000751960?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000d19288?})
reflect.Value.Call({0x1932280?, 0xc000751960?, 0xc000751980?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc000d90000, 0xc000d195a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000d8a008, 0xc00069a458?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc00069a450?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000d96000, 0xc00050d540)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000d92040, 0xf)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0xf)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0xf, 0xf, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de5a0?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 141 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x6?, 0xd0?, 0xc000c16750?)
sync.(*Mutex).lockSlow(0xc000a88224)
sync/mutex.go:92
sync.(*Once).doSlow(0xc000c16750?, 0xc000c16738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc00022e2a0, 0xc000c16880, {0x1ff6a60?, 0xc000512140}, 0xc000c16868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc00022e2a0, {0x1ff6a60, 0xc000512140})
github.com/grafana/sobek.(*SourceTextModuleRecord).Link(0xc000512140)
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0007320a0, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc000732420?, 0xc0004f8b40?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc0004b3288?})
reflect.Value.Call({0x1932280?, 0xc000732420?, 0xc000732440?}, {0x306b440?, 0x120?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc0009087e0, 0xc0004b35a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc0004ec008, 0xc0000b5008?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0000b5000?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc00070f220, 0xc000901040)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000739d40, 0x6)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0x6)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0x6, 0x6, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de600?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 142 [sync.Mutex.Lock]:
sync.runtime_SemacquireMutex(0x4?, 0xa0?, 0xc000bbc750?)
sync/mutex.go:92
sync.(*Once).doSlow(0xc000bbc750?, 0xc000bbc738)
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc0001f8690, 0xc000bbc880, {0x1ff6a60?, 0xc000794780}, 0xc000bbc868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc0001f8690, {0x1ff6a60, 0xc000794780})
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc0007326e0, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc000732a60?, 0x10?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000bbd288?})
reflect.Value.Call({0x1932280?, 0xc000732a60?, 0xc000732a80?}, {0x306b440?, 0xd17ffd?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc0004f85a0, 0xc000bbd5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000c88008, 0xc0000b4298?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc0000b4290?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000262500, 0xc000338730)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc000904080, 0xa)
go.k6.io/k6/js.(*Bundle).Instantiate(0xc0002dadc8, {0x1ff6668, 0xc0002627d0}, 0xa)
go.k6.io/k6/js.(*Runner).newVU(0xc00025c2d0, {0x1ff6668?, 0xc0002627d0?}, 0xa, 0xa, 0xc0001fc620)
go.k6.io/k6/js.(*Runner).NewVU(0xc0008de660?, {0x1ff6668?, 0xc0002627d0?}, 0x0?, 0x0?, 0x100000000000000?)
goroutine 143 [running]:
goroutine running on other thread; stack unavailable
goroutine 144 [runnable]:
github.com/grafana/sobek.(*compiler).compileForInto(0xc000206150, {0x1ff32c0?, 0xc000b94c20}, 0x0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:379 +0x13d
github.com/grafana/sobek.(*compiler).compileLabeledForInOfStatement(0xc000206150, {0x1ff32c0, 0xc000b94c20}, {0x1ff38c0, 0xc000b96de0}, {0x1ff3290, 0xc00075b0e0}, 0x1, 0x0, {0x0, ...})
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:466 +0x8b9
github.com/grafana/sobek.(*compiler).compileLabeledForOfStatement(...)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:495
github.com/grafana/sobek.(*compiler).compileForOfStatement(...)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:491
github.com/grafana/sobek.(*compiler).compileStatement(0xc000206150, {0x1ff3410?, 0xc0006d95c0?}, 0xc5?)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:31 +0x1cd
github.com/grafana/sobek.(*compiler).compileStatements(0xc000206150, {0xc000840300, 0xc, 0x10}, 0x0)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_stmt.go:1110 +0xa8
github.com/grafana/sobek.(*compiledFunctionLiteral).compile(0xc000836f80)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_expr.go:1597 +0xce9
github.com/grafana/sobek.(*compiledFunctionLiteral).emitGetter(0xc000836f80, 0x1)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler_expr.go:1762 +0x31
github.com/grafana/sobek.(*compiler).compileFunction(0xc000206150, 0xc000b98170)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler.go:1516 +0x79
github.com/grafana/sobek.(*compiler).compileFunctions(...)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler.go:1309
github.com/grafana/sobek.(*compiler).compileModule(0xc000206150, 0xc000d34d20)
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/compiler.go:1018 +0xd45
github.com/grafana/sobek.(*SourceTextModuleRecord).InitializeEnvironment.func1()
github.com/grafana/sobek@v0.0.0-20241024150027-d91f02b05e9b/modules_sourcetext.go:555 +0xd0
sync.(*Once).doSlow(0xc000b4a750?, 0x451ea2?)
sync/once.go:76 +0xb4
sync/once.go:67
github.com/grafana/sobek.(*compiler).innerModuleLinking(0xc0002060e0, 0xc000b4a880, {0x1ff6a60?, 0xc000d34d20}, 0xc000b4a868, 0x0)
github.com/grafana/sobek.(*compiler).CyclicModuleRecordConcreteLink(0xc0002060e0, {0x1ff6a60, 0xc000d34d20})
go.k6.io/k6/js/modules.(*ModuleSystem).RunSourceData(0xc000b1c2e0, 0xc00030e7b0)
reflect.Value.call({0x1932280?, 0xc000b1c660?, 0xc000b2e360?}, {0x1c74d3d, 0x4}, {0x306b440, 0x0, 0xc000c9b288?})
reflect.Value.Call({0x1932280?, 0xc000b1c660?, 0xc000b1c680?}, {0x306b440?, 0x120?, 0x35554aaaa?})
github.com/grafana/sobek.(*vm).try(0xc000b26000, 0xc000c9b5a8)
github.com/grafana/sobek.(*Runtime).runWrapped(0xc000b00808, 0xc000b1e0b8?)
github.com/grafana/sobek.AssertFunction.func1({0x0?, 0x0?}, {0x0?, 0x1?, 0xc000b1e0b0?})
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc000b06320, 0xc0005bc810)
go.k6.io/k6/js.(*Bundle).instantiate(0xc0002dadc8, 0xc00071a2c0, 0xc)
