Load testing for video calling sessions
Hey Guys !
At first it’s been great experience in using k6 . You guys are doing a wonderful job.
Can K6 can do load testing for video calling ? Right now the way around that I am trying to set a key value in local storage and try to run test for 10 VUs . Can K6 access and set local storage value.
If there is something else I am missing out please let me know.
It’s very urgent I have to perform load testing for video calls.
Thanks
Regards
Hi, welcome to the forum :slight_smile:
Currently k6 only supports HTTP/1.1, HTTP/2 and WebSockets protocols, so it’s not really suitable for testing real-time streaming services like video calling.
Which protocols would you need support for to test video calling? If it’s something like WebRTC and it exposes a WebSockets bridge endpoint, you might be able to use k6 for that.
No, there’s no support for localStorage in k6. You could emulate it by loading a JS file from disk, though you won’t be able to save it back, so it might not work for you.
If you post a script with what you’re trying to do, we might be able to help you further. :slight_smile:
