Load average - Linux
How do we measure load value if the load is high it should trigger alert?
As of now we are getting load average in grafana+telegraf but how do I estimate the load is high it has correlate with cpu?
Regards
kumar
It really depends on the number of cpu or cores if it is to high.
This article explains it good: https://scoutapm.com/blog/understanding-load-averages
So you can create a alert rule in grafana for this or in prometheus.
Depends on what you want really.
Alerts in grafana are relative simple to implement.
