my line appears once i click on zoom to data button.
It prompt a message"Data Outside time range zoom to data".
Please guide me , is that any kind of cache issue ??? it runs fine once click
Please help
I am facing same issue, is there any workaround?
Also me and there is no clear guide to fix this ![]()
Most probably your datetime column is not utc. Use a function for your data source type to convert the datetime column to utc
i try add UTC and i convert the datetime column to utc, but still face the same issue
