I would like to integrate Grafana in a Java (JDK 1.8) based legacy desktop application. Do you see a chance to operate Grafana UI in a desktop application probably in a Web component? Do you have any success stories or considerations for this?
Thanks for any pointers
Thomas
I gave it a try via a webview panel from JavaFx, it is working nearly 100% beside of some color problems for the grid and the samples. I assume there is a special css setting problem, do you have an idea what might be wrong?
Good in firefox:
Bad in webview:
This is the code for loading:
package test;
import javafx.application.Application;
import javafx.scene.Scene;
import javafx.scene.layout.StackPane;
import javafx.scene.web.*;
import javafx.stage.Stage;
public final class TestBrowser extends Application {
public static void main(String[] args) {
launch(args);
@Override
public void start(Stage stage) throws Exception {
stage.setTitle("JavaFX: WebView");
WebView webView = new WebView();
WebEngine webEngine = webView.getEngine();
String url = "http://192.168.188.87:3000/dashboard/db/host-overview?orgId=1";
webEngine.load(url);
StackPane sp = new StackPane();
sp.getChildren().add(webView);
Scene root = new Scene(sp);
stage.setScene(root);
stage.show();
