I’m having issues with AD LDAP Authentication for Grafana openSource version.
Error:
t=2020-03-20T04:46:25-0400 lvl=dbug msg=“unable to dial LDAP server” logger=ldap host=capos0a000142 port=3269 error=“LDAP Result Code 200 “Network Error”: read tcp 10.193.86.14:59540->10.193.89.11:3269: read: connection reset by peer”
t=2020-03-20T04:46:25-0400 lvl=eror msg=“Error while trying to authenticate user” logger=context userId=0 orgId=0 uname= error=“LDAP Result Code 200 “Network Error”: read tcp 10.193.86.14:59540->10.193.89.11:3269: read: connection reset by peer”
A few facts:
Source Grafana server:
- Grafana Version 6.5.1 (commit: 1763a0f, branch: HEAD)
- the authentication WORKS using port 389, no SSL
- the relevant communication over AD GC SSL ports is opened (3269)
- used server name, IP as the host with the same result (not working)
- grafana.ini
[auth.ldap]
enabled = true
config_file = /etc/grafana/ldap.toml
allow_sign_up = true
level = debug - ldap.toml:
[[servers]]
host = “nameofthehost”
port = 3269
use_ssl = true
start_tls = false
ssl_skip_verify = true
bind_dn = “cn=srv_grafana,ou=Service Accounts,ou=SHD2,dc=shd2,dc=lan”
search_filter = “(sAMAccountName=%s)”
search_base_dns = [“dc=clickfoxshd2,dc=lan”]
[servers.attributes]
name = “givenName”
surname = “sn”
username = “sAMAccountName”
member_of = “memberOf”
email = “email”
[[servers.group_mappings]]
group_dn = “cn=admins,ou=groups,dc=grafana,dc=org”
org_role = “Admin”
group_dn = “cn=g-grafana-admins,ou=Groups,ou=SHD2,dc=shd2,dc=lan”
org_role = “Admin”
group_dn = “cn=g-grafana-viewers,ou=Groups,ou=SHD2,dc=shd2,dc=lan”
org_role = “Viewer”
[[servers.group_mappings]] - openssl to the target server works on 663 or 3269 ports
- no certificates involved
- the same Grafana configuration works on DEV environment
source AD server:
- ldp.exe on ports 389, 636, 3269 works fine using server name or localhost
- cannot find any significant errors in the events
- same situation when using the 2nd AD server
Any suggestions are highly appreciated!
