Grafana Cloud -v9.0.5-d1f1041
Grafana agent iamge -grafana/agent:v0.24.0 -
Configuring Grafana K8s Monitoring -
Followed the Agent Grafana Config instructions from the Grafana Kubernetes menu -
What happened?
Configured Grafana Agent using Terraform but no data is being displayed from the prebuilt Kubernetes Monitoring Dashboards.
From the dashboardClusterdropdown menu, the only option isNone. However, if I manually type the name of my cluster (devops), I can see theEvents(beta)logs temporarily.
I see no error messages from the Grafana Agent pod logs, and the logs look fine but no metrics are collected -
To see all the metrics and logs being displayed from the prebuilt K8s monitoring dashboards -
Terraformis used for configuration. For agent stateful set,kubernetes_deploymentis used withkubernetes_persistent_volumeresource as we have an existing Grafana agent. So I’ve added the K8s monitoring config to the existing deploment resource.
resource "kubernetes_cluster_role" "grafana_agent" {
metadata {
name = "grafana-agent"
rule {
api_groups = [""]
resources = ["nodes", "nodes/proxy", "services", "endpoints", "pods", "events"]
verbs = ["get", "list", "watch"]
rule {
non_resource_urls = ["/metrics"]
verbs = ["get"]
resource "kubernetes_cluster_role_binding" "grafana_agent" {
metadata {
name = "grafana-agent-binding"
role_ref {
api_group = "rbac.authorization.k8s.io"
kind = "ClusterRole"
subject {
kind = "ServiceAccount"
name = ${service_account} # existing service account
namespace = "${namespace}"
resource "kubernetes_service" "grafana_agent" {
metadata {
name = "grafana-agent-service"
labels = {
spec {
type = "ClusterIP"
session_affinity = "None"
selector = {
app = "grafana-agent"
port {
name = "grafana-agent-http-metrics"
port = "80"
target_port = "80"
resource "helm_release" "kube_state_metrics" {
name = "kube-state-metrics"
chart = "kube-state-metrics"
description = "Kube State Metrics"
version = "4.13.0" # https://artifacthub.io/packages/helm/prometheus-community/kube-state-metrics
repository = "https://prometheus-community.github.io/helm-charts"
resource "kubernetes_deployment" "grafana_agent" {
metadata {
labels = {
spec {
replicas = 1
selector {
match_labels = {
template {
metadata {
labels = {
spec {
volume {
name = "grafana-data"
persistent_volume_claim {
claim_name = kubernetes_persistent_volume_claim.grafana_agent.metadata[0].name
volume {
name = "agent-wal"
claim_name = kubernetes_persistent_volume_claim.agent_wal.metadata[0].name
volume {
name = "grafana-agent-config-volume"
config_map {
name = "grafana-agent-config"
container {
volume_mount {
mount_path = "/etc/agent"
volume_mount {
mount_path = "/etc/agent/data"
volume_mount {
name = "agent-wal"
mount_path = "/var/lib/agent"
image = var.grafana_container # grafana/agent:v0.24.0
command = ["/bin/agent"]
env {
name = "HOSTNAME"
value_from {
field_ref {
field_path = "spec.nodeName"
port {
container_port = 80
name = "http-metrics"
args = [
"--config.file=/etc/agent/agent.yaml",
"--enable-features=integrations-next",
"--server.http.address=0.0.0.0:80"
service_account_name = "${service_account}"
data "template_file" "grafana_config" {
template = file("${path.cwd}/agent.yaml")
vars = {
api_key = "${api_key}"
logs_api_key = "${logs_api_key}"
resource "kubernetes_config_map" "grafana_agent_config" {
metadata {
data = {
"agent.yaml" = data.template_file.grafana_config.rendered
resource "google_compute_disk" "grafana_agent" {
type = "pd-standard"
zone = "${var.region}-a"
size = 2
resource "kubernetes_persistent_volume" "grafana_agent" {
depends_on = [
google_compute_disk.grafana_agent
metadata {
annotations = {
"storageclass.kubernetes.io/is-default-class" = "false"
spec {
capacity = {
storage = "2Gi"
access_modes = ["ReadWriteMany"]
persistent_volume_source {
gce_persistent_disk {
pd_name = google_compute_disk.grafana_agent.name
fs_type = "ext4"
storage_class_name = "grafana-data"
resource "kubernetes_persistent_volume_claim" "grafana_agent" {
depends_on = [
kubernetes_persistent_volume.grafana_agent
metadata {
spec {
resources {
requests = {
storage = "2Gi"
volume_name = kubernetes_persistent_volume.grafana_agent.metadata.0.name
resource "google_compute_disk" "agent_wal" {
name = "agent-wal"
size = 2
resource "kubernetes_persistent_volume" "agent_wal" {
depends_on = [
google_compute_disk.agent_wal
metadata {
name = "agent-wal"
annotations = {
spec {
capacity = {
storage = "5Gi"
access_modes = ["ReadWriteOnce"]
pd_name = google_compute_disk.agent_wal.name
fs_type = "ext4"
storage_class_name = "agent-wal"
resource "kubernetes_persistent_volume_claim" "agent_wal" {
depends_on = [
kubernetes_persistent_volume.agent_wal
metadata {
name = "agent-wal"
namespace = "${namespace}""
spec {
resources {
requests = {
storage = "5Gi"
volume_name = kubernetes_persistent_volume.agent_wal.metadata.0.name
agent.yaml
metrics:
wal_directory: /var/lib/agent/wal
global:
scrape_interval: 60s
external_labels:
cluster: devops
configs:
- name: integrations
remote_write:
- url: https://prometheus-prod-01-eu-west-0.grafana.net/api/prom/push
basic_auth:
username: ${username}
password: ${api_key}
integrations:
eventhandler:
cache_path: /var/lib/agent/eventhandler.cache
logs_instance: integrations
logs:
configs:
clients:
- url: https://logs-prod-eu-west-0.grafana.net/loki/api/v1/push
basic_auth:
username: ${username_logs}
password: ${logs_api_key}
external_labels:
cluster: devops
job: integrations/kubernetes/eventhandler
positions:
filename: /tmp/positions.yaml
target_config:
sync_period: 10s
Grafana Agent logs
ts=2022-07-22T13:54:05.983587609Z caller=eventhandler.go:185 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Shipped entry" eventRV=411236 eventMsg="Scheduled for sync"
ts=2022-07-22T13:54:05.983832775Z caller=eventhandler.go:185 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Shipped entry" eventRV=411237 eventMsg="Scheduled for sync"
ts=2022-07-22T13:54:13.709209572Z caller=eventhandler.go:185 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Shipped entry" eventRV=411238 eventMsg="ConfigConnector is up to date"
ts=2022-07-22T13:54:14.745250392Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:54:14.745971372Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:54:24.744470171Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:54:24.745144213Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:54:34.744949177Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:54:34.745565863Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:54:44.744412515Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:54:44.745194398Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:54:54.744941093Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:54:54.745566055Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:55:04.744140744Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:55:04.744722138Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:55:14.744969963Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:55:14.745765097Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:55:24.744526605Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:55:24.744984155Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:55:34.745084381Z caller=eventhandler.go:305 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushing last event to disk"
ts=2022-07-22T13:55:34.745632815Z caller=eventhandler.go:329 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Flushed last event to disk"
ts=2022-07-22T13:55:41.133393668Z caller=eventhandler.go:185 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Shipped entry" eventRV=411240 eventMsg="ConfigConnector is up to date"
ts=2022-07-22T13:55:43.625819867Z caller=eventhandler.go:185 level=info component=integrations integration=eventhandler instance=gke-devops-devops-node-pool-160469fc-8tvs:80 msg="Shipped entry" eventRV=411241 eventMsg="ConfigConnector is up to date"
There are no errors but no data is being displayed. I do not even see the cluster name from the prebuilt dashboard. -
I followed instructions on the Grafana Cloud but also read a lot of official Grafana documentations including - Kubernetes Events (beta) | Grafana Cloud documentation and many other pages
