Dear community out there,
I have a dashboard which monitoring kafka connector status, it’s visualizing as expected.
query used for the visualization:
sum (kafka_connect_connector_metrics{instance=~"$instance", job=~"$job", cluster=~"$cluster",connector=~"$connector",status!=""}) by (status)
Which is giving output something lime this:
- paused Last : 1 * running Last *: 1
so the problem is if we stopped the connector still getting status 1 but time series graph shows in different color for paused and running.
I have created a alert
I have created a alert query:
sum by(status) (kafka_connect_connector_metrics{instance=~".+", job=~"xxxxxx", cluster=~"xxxxxxxx", connector=~"xxxxxxxxxxxxxxxxxxx", status="running"})
alert condition:
Issue: Issue with the alerting, because when paused the connector and i can see in the dashboard that connector stopped, but i am getting value for both running and paused 1, this is reason alert unable to trigger because looking values below 1 but paused status gives also 1, i was hoping to get value 0 when connector paused.
Any idea help in this situation.
Thanks in advance.
