AWS EKS 1.33
public.ecr.aws/karpenter: 1.6.1 values:
values = <<-EOT
serviceMonitor:
enabled: true
nodeSelector:
karpenter.sh/controller: "true"
serviceAccount:
settings:
clusterName: ${module.eks.cluster_name}
clusterEndpoint: ${module.eks.cluster_endpoint}
interruptionQueue: ${module.karpenter.queue_name}
featureGates:
spotToSpotConsolidation: true
tolerations:
- key: CriticalAddonsOnly
operator: Exists
- key: karpenter.sh/controller
operator: Exists
effect: NoSchedule
podAnnotations:
k8s.grafana.com/scrape: "true"
k8s.grafana.com/metrics.path: "/metrics"
webhook:
enabled: false
EOT
k8s-monitoring: 3.2.2 values:
values = <<EOF
# Common tolerations & nodeSelector
_tolerations: &tolerations
tolerations:
- key: "karpenter.sh/controller"
operator: "Equal"
value: "true"
effect: "NoSchedule"
nodeSelector:
cluster:
destinations:
- name: grafana-cloud-metrics
type: prometheus
url: ${local.agent_prometheus_grafana_cloud_url}
auth:
type: basic
username: "${local.agent_prometheus_grafana_cloud_username}"
password: ${local.agent_grafana_cloud_token}
- name: grafana-cloud-logs
type: loki
url: ${local.agent_loki_grafana_cloud_url}
auth:
type: basic
username: "${local.agent_loki_grafana_cloud_username}"
- name: grafana-cloud-otlp-endpoint
type: otlp
url: https://xxxxxxx./otlp
protocol: http
auth:
type: basic
username: "xxxxx"
metrics:
enabled: true
logs:
enabled: true
traces:
enabled: true
clusterMetrics:
enabled: true
<<: *tolerations
kepler:
enabled: true
<<: *tolerations
kube-state-metrics:
enabled: true
<<: *tolerations
node-exporter:
enabled: true
<<: *tolerations
annotationAutodiscovery:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
prometheusOperatorObjects:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
clusterEvents:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
podLogs:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
applicationObservability:
enabled: true
<<: *tolerations
receivers:
otlp:
grpc:
enabled: true
port: 4317
http:
enabled: true
port: 4318
zipkin:
enabled: true
port: 9411
connectors:
grafanaCloudMetrics:
enabled: true
integrations:
alloy:
instances:
- name: alloy
labelSelectors:
app.kubernetes.io/name:
- alloy-metrics
- alloy-singleton
- alloy-logs
- alloy-receiver
- true
alloy-metrics:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
alloy-singleton:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
alloy-logs:
enabled: true
<<: *tolerations
controller:
<<: *tolerations
alloy-operator:
<<: *tolerations
alloy-receiver:
enabled: true
<<: *tolerations
alloy:
extraPorts:
- name: otlp-grpc
port: 4317
targetPort: 4317
protocol: TCP
- name: otlp-http
port: 4318
targetPort: 4318
protocol: TCP
- name: zipkin
port: 9411
targetPort: 9411
protocol: TCP
controller:
<<: *tolerations
EOF
k describe pod karpenter-autoscaler-6858d846d6-szq4r -n kube-system
Namespace: kube-system
Priority: 2000000000
Priority Class Name: system-cluster-critical
Service Account: karpenter
Node: ip-10-63-2-27.eu-central-1.compute.internal/10.63.2.27
Start Time: Tue, 05 Aug 2025 13:47:36 +0200
Labels: app.kubernetes.io/instance=karpenter-autoscaler
app.kubernetes.io/name=karpenter
pod-template-hash=6858d846d6
Annotations: k8s.grafana.com/metrics.path: /metrics
k8s.grafana.com/scrape: true
Status: Running
SeccompProfile: RuntimeDefault
IP: 10.63.2.234
for test added annotations to service but no difference.
Only karpenter_cloud are available
but metrics endpoint shows
karpenter_nodes_total_pod_requests
karpenter_nodes_total_pod_limits
are exist
Any thoughts ?
