Hello ![]()
I am busy implementing k6 on our CI/CD pipeline.
We have set up a VM to run all k6 tests.
Currently, I have 2 tests active: Smoke and a Load test. Both utilize the code below:
import { check, group } from 'k6';
import http from 'k6/http';
const user_data = JSON.parse(open(`${__ENV.USERS_FOR_VU}`));
// Test configuration
export let options = JSON.parse(open(`${__ENV.TEST_CONFIG}`));
// User scenario
export default function () {
group('Init Auth Call to Sign In page', function () {
let spa_response;
spa_response = http.get(`${__ENV.TEST_HOSTNAME}`);
check(spa_response, {
'is app status 200': (r) => r.status === 200
group('Sign In to ids4 and inspect user for sign in access', function () {
let userNumber = Math.floor((Math.random() * (user_data.users.length)));
let vu_user = user_data.users[userNumber];
spa_response = spa_response.submitForm({
formSelector: 'form',
fields: {
Username: vu_user.username,
Password: vu_user.userpassword,
RememberLogin: false
'is login request status 200': (r) => r.status === 200
However when running the test via PS on the VM via the pipeline I get the following error for every iteration:
time="2021-03-26T15:39:24Z" level=warning msg="Request Failed" error="Get \"\": unsupported protocol scheme \"\"" time="2021-03-26T15:39:24Z" level=error msg="GoError: invalid response type\n\tat reflect.methodValueCall (native)\n\tat file:///C:/azagent/A2/_work/3/s/src/test-scripts/ci-load-smoke-test-v1.js:27:36(36)\n\tat github.com/loadimpact/k6/js/common.Bind.func1 (native)\n\tat file:///C:/azagent/A2/_work/3/s/src/test-scripts/ci-load-smoke-test-v1.js:19:23(29)\n\tat github.com/loadimpact/k6/js/common.Bind.func1 (native)\n\tat file:///C:/azagent/A2/_work/3/s/src/test-scripts/ci-load-smoke-test-v1.js:11:19(5)\n" executor=ramping-vus scenario=default source=stacktrace
However when running the above directly on the VM again using PS the test runs and completes as expected.
Has anybody seen something similar?
I Should mention the VM is on Azure as is our CI/CD pipeline (Azure DevOps).
