newly trying out k6, and there’s something i am not getting. if i run the following “test”:
gdate +%s.%N ; curl <demo-url>/clients ;echo "" ; gdate +%s.%N
on my mac, i get a result:
1730735650.745561000
[{"id":1,"name":"Zasu Pitts","email":"pitts@silents.com"},{"id":2,"name":"Theda Bara","email":"bara@silents.com"},{"id":3,"name":"Lon Chaney","email":"chaney@silents.com"},{"id":4,"name":"Clara Bow","email":"clarabow@silents.com"},{"id":5,"name":"Rudolph Valentino","email":"valentino@silents.com"},{"id":6,"name":"Lillian Gish","email":"gish@silents.com"},{"id":7,"name":"John Garfield","email":"garfield@silents.com"},{"id":8,"name":"Douglas Fairbanks","email":"fairbanks@ss.com"},{"id":9,"name":"Buster Keaton","email":"keaton@silents.com"},{"id":10,"name":"Mary Pickford","email":"pickford@silents.com"}]
1730735650.819227000
which looks to me like it took all of 0.07 seconds.
if i run the same as a k6 invocation:
import http from 'k6/http';
import { sleep } from 'k6';
export default function () {
http.get('http://<demo-url>/clients');
sleep(1);
i get results that seem to me to indicate it took almost a second for the api call:
k6 run single-test.js
/\ Grafana /‾‾/
/\ / \ |\ __ / /
/ __________ \ |_|\_\ \_____/
execution: local
script: single-test.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
data_received..................: 944 B 902 B/s
data_sent......................: 132 B 126 B/s
http_req_blocked...............: avg=18.32ms min=18.32ms med=18.32ms max=18.32ms p(90)=18.32ms p(95)=18.32ms
http_req_connecting............: avg=16.24ms min=16.24ms med=16.24ms max=16.24ms p(90)=16.24ms p(95)=16.24ms
http_req_duration..............: avg=22.91ms min=22.91ms med=22.91ms max=22.91ms p(90)=22.91ms p(95)=22.91ms
{ expected_response:true }...: avg=22.91ms min=22.91ms med=22.91ms max=22.91ms p(90)=22.91ms p(95)=22.91ms
http_req_failed................: 0.00% 0 out of 1
http_req_receiving.............: avg=165µs min=165µs med=165µs max=165µs p(90)=165µs p(95)=165µs
http_req_sending...............: avg=102µs min=102µs med=102µs max=102µs p(90)=102µs p(95)=102µs
http_req_tls_handshaking.......: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_waiting...............: avg=22.64ms min=22.64ms med=22.64ms max=22.64ms p(90)=22.64ms p(95)=22.64ms
http_reqs......................: 1 0.955789/s
iteration_duration.............: avg=1.04s min=1.04s med=1.04s max=1.04s p(90)=1.04s p(95)=1.04s
iterations.....................: 1 0.955789/s
vus............................: 1 min=1 max=1
vus_max........................: 1 min=1 max=1
running (00m01.0s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 00m01.0s/10m0s 1/1 iters, 1 per VU
which, if i am reading correctly, says it took 1.04 seconds. i’ve tried a few different configurations, and that 1 second result is pretty consistent.
so, i assume i am either reading this wrong or implementing it wrong. any help appreciated, thanks
