Execution timed out after 120 seconds
We’re running some longer tests using K6 (local, non-cloud) (eg 3-4 hours) and we’re seeing the following in the log output at the end of the test when it is trying to generate the summary:
{"level":"info","msg":"[k6-reporter v2.3.0] Generating HTML summary report","source":"console","time":"2024-09-17T07:00:17Z"}
{"level":"error","msg":"context canceled at __append (\u003ceval\u003e:8:73(12))","time":"2024-09-17T07:02:17Z"}
{"error":"handleSummary() execution timed out after 120 seconds","level":"error","msg":"failed to handle the end-of-test summary","time":"2024-09-17T07:02:43Z"}
Has anyone else come across this and if so, what is the recommended approach to handle this?
Hi @mto :wave:
Welcome to the forum :tada:
I was not aware of it myself, but it does appear that the handleSummary function is subject to a 120-second timeout. It also doesn’t seem to be customizable either.
120s to generate a test summary sounds like a lot, too, but in the context of an hours-long test, I’m not necessarily astonished, considering the amount of metrics data that might have been generated by your test.
Would you be able to share a simplified and anonymized version of the test you’re running so we can try to spot potential workarounds?
:bowing_man:
Thanks @oleiade, apologies for the delay. Let me see if I can get something together script-wise to share.
Our aim is to be able to use k6 for endurance tests of 24 or 48 hours internally, so definitely keen to understand how we can get the shorter tests working first.
Thanks, I’ll be in touch again.
Hey @oleiade ,
I’ve got an anonymized version of the script that I’m happy to share, I tried to upload the file but only images are allowed, so it is below.
Any feedback is appreciated. Thanks, mto.
// Creator: Grafana k6 Browser Recorder 1.0.4
import { sleep, group } from 'k6'
import http from 'k6/http'
import { getSessionData } from './utils/k6-common.js'
// This script has been anonymized and as such, it is not expected to run successfully.
// https://community.grafana.com/t/execution-timed-out-after-120-seconds/132323/3
// Constants
const host = 'qatest-anon.com'
const protocol = 'https://'
const baseUrl = protocol + host
const baseUrlApplication = protocol + host + '/our-application'
const userAgent = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36'
const sleepInSeconds = 1 // for milliseconds, use 0.x notation eg 500ms = 0.5
const debugOutput = false
const maxVUs = 200
// Test parameters
export const options = {
  discardResponseBodies: false, // will affect checking the response.  If you do need the response from a specific request, then you'll need to use "responseType: 'text'" on the HTTP call.
  systemTags: ['status', 'method', 'error', 'error_code'],
  thresholds: {
    http_req_failed: ['rate<0.01'], // http errors should be less than 1%
    //http_req_duration: ['p(95)<1500'], // N% of requests should be below this value (milliseconds)
    'http_req_failed{status:401}': ['rate<=0.01'],
    'http_req_failed{status:403}': ['rate<=0.01'],
    'http_req_failed{status:408}': ['rate<=0.01'],
    'http_req_failed{status:429}': ['rate<=0.01'],
    'http_req_failed{status:500}': ['rate<=0.01'],
    'http_req_failed{status:503}': ['rate<=0.01'],
    'http_req_failed{status:504}': ['rate<=0.01'],
  'summaryTrendStats': ['min', 'med', 'avg', 'p(90)', 'p(95)', 'max', 'count'],
  stages: [
      duration: '60s',
      target: maxVUs
      duration: '1700s',
      target: maxVUs
      duration: '60s',
      target: 0
export default function main() {
  let response;
  let data;
  group(
    'page_1 - ' + baseUrl + '/wd/start/test',
    function () {
      response = http.get(
        '' + baseUrl + '/wd/start/test',
          responseType: 'text',
          headers: {
            'upgrade-insecure-requests': '1',
            'host': '' + host + '',
            'user-agent': userAgent,
            accept:
              'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8',
            'accept-language': 'en-AU,en-US;q=0.7,en;q=0.3',
            'accept-encoding': 'gzip, deflate, br',
            connection: 'keep-alive',
            'sec-fetch-dest': 'document',
            'sec-fetch-mode': 'navigate',
            'sec-fetch-site': 'none',
            'sec-fetch-user': '?1',
      data = getSessionData(response, debugOutput);
        '' + baseUrl + '/wd/staticresource/main.css?id=11f67748fdca4e86',
          headers: {
            accept: 'text/css,*/*;q=0.1',
            referer:
            'sec-fetch-dest': 'style',
            'sec-fetch-mode': 'no-cors',
            'sec-fetch-site': 'same-origin',
        '' + baseUrl + '/wd/staticresource/fonts/fonts.css',
          headers: {
            referer:
        '' + baseUrl + '/wd/staticresource/main.js?id=d23a41699b122ec7',
          headers: {
            accept: '*/*',
            referer:
            'sec-fetch-dest': 'script',
  group(
    'page_2 - ' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%2436ef40a9-47d2-435a-a337-8caa1b78ba0c%24global%24global',
    function () {
        '' + baseUrlApplication +  '/' + data['sessionId'] + '/resource/test/en/images/91a2fdb6-c889-4764-87bf-2902e9274eef.png',
          tags: { name: 'url-tag-1' },
          headers: {
            accept: '*/*',
            'x-id': '' + data['xId'] + '',
            'content-type': 'text/plain',
            origin: protocol + host,
            referer:
              '' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%2436ef40a9-47d2-435a-a337-8caa1b78ba0c%24global%24global',
            'sec-fetch-dest': 'empty',
            'sec-fetch-mode': 'cors',
      response = http.post(
        '' + baseUrlApplication +  '/' + data['sessionId'] + '/JSON/test/en/Screen-qs%2436ef40a9-47d2-435a-a337-8caa1b78ba0c%24global%24global',
        '{"data":[],"operation":"submit"}',
          headers: {
            accept: '*/*',
            referer:
  group(
    'page_3 - ' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%2454f36dc2-6403-4ffa-b7ee-ffb75c3997e0%24global%24global',
    function () {
        '' + baseUrlApplication +  '/' + data['sessionId'] + '/JSON/test/en/Screen-qs%2454f36dc2-6403-4ffa-b7ee-ffb75c3997e0%24global%24global',
        '{"data":[{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[{"field":"parent_name","value":"Parent1"},{"field":"food_requirements","value":false}],"relationships":[],"collected":[],"uploads":[]}]}],"operation":"submit"}',
          tags: { name: 'url-tag-2' },
          headers: {
            accept: '*/*',
            referer:
              '' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%2454f36dc2-6403-4ffa-b7ee-ffb75c3997e0%24global%24global',
  group(
    'page_4 - ' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%24b3a35b86-b642-4797-9abe-049c57b1f614%24global%24global',
    function () {
        '' + baseUrlApplication +  '/' + data['sessionId'] + '/JSON/test/en/Screen-qs%24b3a35b86-b642-4797-9abe-049c57b1f614%24global%24global',
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":""},{"field":"child_veg","value":{"dataType":"<uncertain>"}},{"field":"child_grains","value":{"dataType":"<uncertain>"}},{"field":"child_fruit","value":{"dataType":"<uncertain>"}},{"field":"child_dairy","value":{"dataType":"<uncertain>"}},{"field":"child_meat","value":{"dataType":"<uncertain>"}},{"field":"child_sweets","value":{"dataType":"<uncertain>"}}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"recalc"}',
          tags: { name: 'url-tag-3' },
          headers: {
            accept: '*/*',
            referer:
              '' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%24b3a35b86-b642-4797-9abe-049c57b1f614%24global%24global',
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":"Child1"},{"field":"child_veg","value":{"dataType":"<uncertain>"}},{"field":"child_grains","value":{"dataType":"<uncertain>"}},{"field":"child_fruit","value":{"dataType":"<uncertain>"}},{"field":"child_dairy","value":{"dataType":"<uncertain>"}},{"field":"child_meat","value":{"dataType":"<uncertain>"}},{"field":"child_sweets","value":{"dataType":"<uncertain>"}}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"recalc"}',
          headers: {
            accept: '*/*',
            referer:
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":"Child1"},{"field":"child_veg","value":1},{"field":"child_grains","value":2},{"field":"child_fruit","value":{"dataType":"<uncertain>"}},{"field":"child_dairy","value":{"dataType":"<uncertain>"}},{"field":"child_meat","value":{"dataType":"<uncertain>"}},{"field":"child_sweets","value":{"dataType":"<uncertain>"}}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"recalc"}',
          headers: {
            accept: '*/*',
            referer:
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":"Child1"},{"field":"child_veg","value":1},{"field":"child_grains","value":2},{"field":"child_fruit","value":3},{"field":"child_dairy","value":2},{"field":"child_meat","value":3},{"field":"child_sweets","value":{"dataType":"<uncertain>"}}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"recalc"}',
          headers: {
            accept: '*/*',
            referer:
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":"Child1"},{"field":"child_veg","value":1},{"field":"child_grains","value":2},{"field":"child_fruit","value":3},{"field":"child_dairy","value":2},{"field":"child_meat","value":3},{"field":"child_sweets","value":1}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"recalc"}',
          headers: {
            accept: '*/*',
            referer:
        '{"data":[{"entityId":"child","instances":[{"entityId":"child","instanceName":"the child1","parentId":{"entityId":"someEntity","instanceName":"someEntity"},"attributes":[{"field":"child_name","value":"Child1"},{"field":"child_veg","value":1},{"field":"child_grains","value":2},{"field":"child_fruit","value":3},{"field":"child_dairy","value":2},{"field":"child_meat","value":3},{"field":"child_sweets","value":1}],"relationships":[],"collected":[],"uploads":[]}]},{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[],"relationships":[],"collected":["child"],"uploads":[]}]}],"operation":"submit"}',
          headers: {
            accept: '*/*',
            referer:
  group(
    'page_5 - ' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%24fcc74cca-d8ac-4309-8063-82286ba0d642%24global%24global',
    function () {
        '' + baseUrlApplication +  '/' + data['sessionId'] + '/JSON/test/en/Screen-qs%24fcc74cca-d8ac-4309-8063-82286ba0d642%24global%24global',
        '{"data":[{"entityId":"someEntity","instances":[{"entityId":"someEntity","instanceName":"someEntity","attributes":[{"field":"assessor_name","value":"Abc"},{"field":"assessment_date","value":"2024-07-11"}],"relationships":[],"collected":[],"uploads":[],"signature":{"signatureOperation":"set","data":"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","fileName":"myfile.png"}}]}],"operation":"submit"}',
          tags: { name: 'url-tag-4' },
          headers: {
            accept: '*/*',
            referer:
              '' + baseUrlApplication +  '/' + data['sessionId'] + '/test/Screen-qs%24fcc74cca-d8ac-4309-8063-82286ba0d642%24global%24global',
  // Automatically added sleep
  sleep(sleepInSeconds)
