K6 Skip TLS verify not working, Getting error failed to verify certificate: x509
I have been trying skip TLS verify in K6 scripts.
tried passing “insecureSkipTLSVerify: true” in options
passed as flag (–insecure-skip-tls-verify)
After applying above solutions However still getting below error:
msg=“Failed to send the time series data to the endpoint” error=“HTTP POST request failed: Post "[https://.../api/v1/push](https://.../api/v1/push/)”: tls: failed to verify certificate: x509: certificate signed by unknown authority" output=“Prometheus remote write”
TLS handshake is happening still
Any help/pointers are appreciated.
Thanks in advance
Hi @rahulatreysharma
From the error message I assume it occurs while sending the metrics to the prometheus server.
Please try to set the K6_PROMETHEUS_RW_INSECURE_SKIP_TLS_VERIFY environment variable to true also.
Let me know if it helps.
Thank you so much @bandorko Balazs Andorko.
It worked after setting K6_PROMETHEUS_RW_INSECURE_SKIP_TLS_VERIFY environment variable.
