Thanks, to all the supports I have received so far. I appreciate the genius that had contributed.
K6, InfluxDb, and Grafana are working perfectly locally on my Windows system. Because I’ll need to showcase it to the stakeholders remotely, I have installed another set of InfluxDB and Grafana on a Ubuntu-20.04 server on Google Cloud, I want to run the test from my local machine and output the result on the remote InfluxDB and Grafana, but K6 could not create the database. I’m getting the following error output.
ERRO[0003] InfluxDB: Couldn't write stats error="{\"error\":\"database not found: \\\"default\\\"\"}\n"
r
running (00m01.6s), 0/1 VUs, 1 complete and 0 interrupted iterations0
default ✓ [======================================] 1 VUs 00m01.5s/10m0s 1/1 iters, 1 per VU
data_received..............: 11 kB 6.9 kB/s
data_sent..................: 76 B 47 B/s
http_req_blocked...........: avg=311.23ms min=311.23ms med=311.23ms max=311.23ms p(90)=311.23ms p(95)=311.23ms
http_req_connecting........: avg=179.08ms min=179.08ms med=179.08ms max=179.08ms p(90)=179.08ms p(95)=179.08ms
http_req_duration..........: avg=207.74ms min=207.74ms med=207.74ms max=207.74ms p(90)=207.74ms p(95)=207.74ms
http_req_receiving.........: avg=5ms min=5ms med=5ms max=5ms p(90)=5ms p(95)=5ms
http_req_sending...........: avg=1ms min=1ms med=1ms max=1ms p(90)=1ms p(95)=1ms
http_req_tls_handshaking...: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_waiting...........: avg=201.73ms min=201.73ms med=201.73ms max=201.73ms p(90)=201.73ms p(95)=201.73ms
http_reqs..................: 1 0.629347/s
iteration_duration.........: avg=1.51s min=1.51s med=1.51s max=1.51s p(90)=1.51s p(95)=1.51s
iterations.................: 1 0.629347/s
vus........................: 1 min=1 max=1
vus_max....................: 1 min=1 max=1
ERRO[0004] InfluxDB: Couldn't write stats error="{\"error\":\"database not found: \\\"default\\\"\"}\n"
I issued this on the command line
k6 run -o influxdb=http://test.domain.com:8086/default default.js
